oil pressure guage problem
My oil pressure gauge is leaking. I cannot find the correct fitting to attach to it. I even bought a new tube kit with assorted fittings and none will fit it. I bought some other fittings so it is stacked 3 adapters high and it still leaks. Does anyone have a part number for the correct fitting?
Thanks, |
Re: oil pressure guage problem
Which end?
On the motor or on the gauge? |
on the gauge end.
This is what I need. The ferrule is worn due to over tightening.
. This is what I have been able to find locally. It leaks even with teflon tape etc. |
![]() Join Date: Feb 2016
From what part of the fitting is it leaking?
If it is from around the tube you may have to cut the tube off just above where the old ferrule was and replace the old ferrule with a new one. I got my new one from NAPA. Then snug the fitting nut down on the ferrule. Do not overtighten the nut you will deform the tube and it will not seal.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#7 | |
The Older Generation
I have some of the compression sleeve nuts if you can't find one. I also have the complete oil line kits with all of the correct fittings for our trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=788124 LockDoc
If LockDoc can't help, I do know that Truck Car Shop in Orange, CA has replacement copper line with correct fittings each end for cheap.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
