10-20-2020, 11:07 AM | #1 |
Old member
67/68 steering wheel
I've had this wheel now for a couple of years. I took a stock wheel and cut it down. I have it all back welded but haven't been able to figure out a good simple way to do the hand grips that need replacing.
Has anyone got any suggestions? Anything that could get this project back together. It has sat like this for over a year now. I like to finish it up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
10-20-2020, 12:11 PM | #2 |
Re: 67/68 steering wheel
I cut down a wheel for a 50 using an original 50 center and a 69 Camaro ring. The places I had gaps I used PC7 epoxy paste to build up the area and then form it to match the original contour of the wheel. Most people can't tell its not the original diameter after painting. It takes time to get it all smooth.
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors '72 3/4 Cheyenne Super 350/200R4 '50 1/2 Chevy 3 Window |
10-20-2020, 12:29 PM | #3 | |
Old member
I have 2 things of the PC7 but how do you put it on. Does it not harden before you can get a whole section on? That's what I'm worried about.
