Old 10-22-2020, 03:26 PM   #26
Low Elco
Re: QA1 Coil Over System
Also, there's an episode of hot rod garage where they install a full kit. And check out lucky's garage/lucky costa on YT. He has an awesome beater C10 he did the QA1 to. Nice truck!
Low Elco is offline   Reply With Quote
Old 10-22-2020, 04:45 PM   #27
bigmac73
bigmac73's Avatar
Originally Posted by SIXTY9 View Post
bigmac73,
Here is the list and part numbers. I got them thru JEGS.
UPPER
Steel Double D U-Joint
1" DD X 13/16" - 36 Spline
153-015240
LOWER
3/4" - 36 Spline X 3/4" DD
153-013449
Telescoping Double D Steering Shaft
3/4" X DD X 1" DD X 26" Long
555-607102
Wally
are those all standard size , and will this just bolt right in?
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-23-2020, 08:33 AM   #28
SIXTY9
bigmac73,
Yes those are standard sizes, not metric. I have a 75 steering box with a 72 tilt column.
they bolted right up and I did have to cut the shaft to length. The original steering shaft was from the 69. Hope this helps.
Wally
SIXTY9 is offline   Reply With Quote
Old 10-25-2020, 05:17 PM   #29
Gassy
Gassy's Avatar
Hey Speedtacer, I had the western chassis heavy duty 2 piece bolt in c notch and I just trimmed it to mate up to the QA1 coil over mounts the welded them together. Turned out decent.
Gassy is offline   Reply With Quote
Old 10-25-2020, 07:22 PM   #30
Speedracer39
Speedracer39's Avatar
Thanks for the picture, That’s a great idea and it looks fantastic.
Speedracer39 is offline   Reply With Quote
