10-23-2020, 11:29 PM | #1 |
74 / 88 Suburban ?????????
I recently bought a 74 Suburban , LS Swapped and drives great , But the interior / seats need help . Had an upholstery shop tell me $3600 to recover the seats , front bench , 2 rear benches .
Have just bought an 88 Burb with better seats , will they be a direct swap to the 74 Burb , Bench front and both rears ? Also want the Seat Belts as they are 3 point , same question , will they be a direct swap to the 74 ? My plan is to swap these items if they are a direct swap then resell the 88 Burb once we get it running . Any help much appreciated , dont have possession of the 88 Burb yet . |
10-24-2020, 11:10 AM | #2 |
Moderator
Re: 74 / 88 Suburban ?????????
I believe all 7th generation Suburban's (1973 - 1981) used a common floor pattern so the seat bolt holes should all be there in the floor.
They all use a common wheelbase of 129.5 inches... Question...Are you changing the door trims? Are both vehicles fitted with either wind up windows or power windows? Not sure about 3 point seat belt mounting points on door pillars....I dont believe the 74 has them .... Hope this helps out...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-24-2020, 11:42 AM | #3 |
Both have manual windows , not changing anything there on either one . My 74 has full outside trim , uppers and lowers , the 88 is a plain Jane version with no trim , was a Fire Dept truck in Texas .
Just got the 88 home so I can start investigating what will interchange . |
10-25-2020, 09:22 PM | #4 |
The 74 Suburban does have provisions / mount holes in door pillers for the next one doing what I am .
Also it appears the floor seat belt holes are the same . |
10-26-2020, 06:34 AM | #5 |
Cool. I know it's not essential for your task at hand, but let's see some pictures!
10-26-2020, 11:01 AM | #6 |
Unfortunately I have never figured out how to post pics here . I wish it was as easy as it is on Facebook.
