10-23-2020, 12:49 PM | #101 | |
Re: Mike D's 50 pickup build
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
10-23-2020, 01:43 PM | #102 |
Thank you, just a cam and a tune on a 6 litre LQ4. I don't notice the power that much but all the cars seem to disappear in my rear view mirror when i pull away from a light, lol.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 Last edited by Thesilverfox; 10-23-2020 at 01:48 PM. |
10-23-2020, 01:55 PM | #103 |
Yeah, lol. Truck was a mess overall especially the cracked frame at the cab mounts.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=711003 |
10-27-2020, 02:50 AM | #104 |
Man, you've done a wicked job. I'm also from Alberta and am building a red 53 on air ride.
10-27-2020, 10:14 AM | #105 |
looks really good,
Now it's time to enjoy driving it Thanks for sharing the build
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
10-27-2020, 01:33 PM | #106 |
great looking truck !!!!---have a great time putting miles on it-----Hail Canada !!!!
10-27-2020, 01:46 PM | #107 |
That is a sweet ride. Hope to see it around next summer.
10-27-2020, 07:56 PM | #108 |
Thank you for the compliments. There's so much passion that goes into these builds. I admire anyone who can complete a project like this or similar on this forum.
10-28-2020, 04:52 PM | #109 | |
VERY nice build. I (thought) I prefer(ed) shiny paint but now after having done it I can't drive my truck anywhere without worrying about it getting dinged! Kinda jealous of not having to wnorry about it. Can you provide the cam info? I have an LQ4 in my '55 that the builder put a "mild cam" in - whatever that is - but it's not been on a dyno to be tuned. Also, what rearend ratio are you running? I'm not sure what mine is but it's a limited slip Ford 8.8 with 4l85e trans in it.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
10-28-2020, 05:09 PM | #110 | |
It's a Comp Cam part# 54-535-11, it is also considered a mild cam. Basic Operating RPM Range: 1,200-6,200 Intake Duration at 050 inch Lift: 210 Exhaust Duration at 050 inch Lift: 218 Duration at 050 inch Lift: 210 int./218 exh. Advertised Intake Duration: 262 Advertised Exhaust Duration: 270 Advertised Duration: 262 int./270 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.513 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.507 in. Valve Lift with Factory Rocker Arm Ratio: 0.513 int./0.507 exh. Lobe Separation (degrees): 115 Push Rods, have part number Comp Cam CCA-7950-16. 7.350" to give a little more than 0.050" preload on the lifter. Forgot the valve springs, but could look it up if you want. Rear end is a Ford 9 Inch, Eaton truetrac differential and pinion bevel is 3.5:1 Shinny paint jobs are stressful for me but your truck looks awesome.
10-29-2020, 01:01 AM | #111 |
Hey Dan, love that color. Nice.
