#1576 | |
Re: What did you do to your truck today.The 3rd chapter
Do it, Do it right, Do it right the first time |
#1577 |
![]() Join Date: Jul 2018
New windshield installed...getting closer. Granted my glass guy only had to put the gasket and install the glass, but he was in and out in less than an hour!
1971 Custom/10 - 350/3 speed, Orange/White roof |
#1578 |
About three weeks ago, my radiator let me know it wanted attention: when I got home from work, it was steaming. The leak appeared to be in the engine-side up near the top. a few days later, I backed the truck into the garage and pulled the radiator. Then my wife broke her ankle and needed surgery, so my time to work on the truck has been limited. I managed to get the rad up to what appears to be the only radiator shop in this time zone, and they're 3 weeks behind on work, so we'll see that they say when they can.
I popped the cap off the distributor today, and it's time for cap, rotor, module, coil (probably--why not while I've got it in pieces). I also checked a spark plug, and the electrodes are beginning to erode, so I guess he wants a set of them, too. I think he's just jealous: I have been putting money and work into the tractors all summer, and he feels neglected, so he's making me spend money on him now. *sigh*
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#1579 |
![]() Join Date: Feb 2016
Added some chrome to the firewall
![]() Actually I put the foil over the wiring for my Gearvendor unit. A couple weeks back I ditched the HEI and replaced it with a Pertronix unit and a Pertronix coil. Several days later the Gearvendors controller started freaking out. The unit was lighting both lights and jumping in and out of overdrive. As a short term fix I unplugged it to prevent damage to the system. It took me several days to put 2 and 2 together when it dawned on me that possibly the improved spark the new ignition was providing might be inducing electrical noise into the wiring for the overdrive controller. Wrapping the wiring near the ignition should prevent the induction of stray voltage. So far so good, I drove to work and back with no problems. I will keep the foil on for a week or 2 just to be sure it solves the problem? Then a real solution will have to be developed.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#1580 |
![]() Join Date: Aug 2019
Electrical noise is best solved with a dedicated ground back to the battery.
#1581 |
![]() Join Date: Jun 2014
Checked and changed gear oil in back axle. Cleaned up brake drums, installed new brake cylinders, shoes and hardware.
#1582 | |
I believe the induced voltage is affecting the speed sensor signal. The GV supplied wiring is not shielded which for the price of a GV seems shoddy.
#1583 |
![]() ![]() Join Date: Jan 2005
Repainted my dash
#1584 |
The Older Generation
I have been driving the '68 Custom Sport Truck once in a while and even though it has a 327/TH400 with power steering and brakes it is a little bit cumbersome because of the low geared rear end. Not sure if it is a 4.11 or 4.57 I haven't taken the time to check it out. This morning I decided to put the Dana 60 coil spring 3.54 rear end in it that I have had for quite a while. I got all of the "U" bolt nuts broke loose and the "U" bolts free of the trailing arms on the '68. The Dana was sitting under the '70 Chevy pickup that has a '72 GMC leaf spring frame under it, and it was not bolted in. I pulled the Dana out and started cleaning it up and checking it out. I have all new brake parts for it so that will make that part easy. I have other plans for the '70 Chevy/GMC and put the rear end out of another truck in it this afternoon. I will post about that after I get the '68 done. The weather has been beautiful here all last week and is supposed to be decent tomorrow but then it is going to start getting colder and rain/snow mix. If that happens things will slow down because I am doing this outside. LockDoc
#1585 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#1586 |
Stripped and painted the trans hump . While I was doing it my wife asked where it goes I showed her . She then said “ So it under the mat why are getting so fussy about it ? Told her I’ll know what it looks like under the mat . She responded .” You need help” said no not really it’s a small part I can do it by myself . She rolled her eyes and laughed.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 11-10-2020 at 08:57 PM. |
#1587 |
I reset the odometer on a replacement speedometer I'll be putting in my truck. I matched it to my current mileage. It's out of a 67 cluster, and the odometer didn't have the delicate plastic piece shown in older threads on the topic. Made it pretty easy to reset. The metal bar that the odometer fingers engage with goes the full width so no plastic piece is needed. I sprayed some paint on the needle as well. Hopefully this speedometer won't drift around like my current speedometer does. I already replaced the cable and it had no effect.
#1588 |
I'm thinking so too Dale. LockDoc
#1589 |
![]() Join Date: Mar 2019
I've been making some progress on the sheet metal / body work and got the little 6 fired up but now it's almost time to put away for the winter.
#1590 |
![]() Join Date: Jul 2001
Put the wheels & tires on, trans cooler lines installed, and all the hardware installed in the tailgate. Waiting on trim rings for the wheels.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 Last edited by TxGary; 11-11-2020 at 12:15 AM. |
#1591 | |
Who Changed This?
![]() Join Date: Jan 2013
#1592 |
![]() Join Date: Oct 2013
Finally got to test drive the truck, after installing Redhead steering box. Man, what a difference! Sucker turns quick now.
#1593 |
For some reason it was 80 degrees yesterday in November in Cleveland, OH so I did some last minute work.
Have had a leaking lift pump on my diesel powered 72 for the last 6 months. My dog runs underneath and comes out with diesel fuel on her back stinking the house up. Also had time to pull the 10 bolt out of my 85 Monte Carlo SS for the Ford 9" I purchased. Overall productive day while still dealing with a 3yr old and 1yr old.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#1594 |
![]() Join Date: Nov 2014
Underside of my hood has a second layer of sheetmetal in the center. I’m guessing to stop or at least limit the hood shake. Painted the underside with Rustoleum Satin black.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#1595 |
Painted and installed a set of rally wheels
#1596 |
#1597 |
Who Changed This?
<Cries silently into beer> Someday I will find a long bed step side. It will have to be close by and rust-free, which is the thing that leaves me <Crying silently into my beer>When the stars align, I'll sell 3 or 4 of my wife's sewing machines to pay for it.
#1598 | |
https://sacramento.craigslist.org/ct...232564904.html |
#1599 | |
Who Changed This?
#1600 |
Put the 3rd set of engine badges on my truck. These are the closest to right.CNC from kniesmachine@hotmail.com.
