Old 11-03-2020, 01:31 AM   #51
geezer#99
geezer#99's Avatar
Re: 1980 smog
Geez!
You’re gonna have fun!
Neither of those intakes will work. You’ll need one with an egr valve on it. And an adapter from your squarebore carb to a spreadbore intake.
Old 11-03-2020, 01:39 AM   #52
malc1080
Re: 1980 smog
Originally Posted by geezer#99 View Post
Geez!
no im replacing the carb to spreadbore california approved carb from holley. you saved me from buying it. I had a deal to buy the blue one tomorrow.
so egr valve goes to the intake?
malc1080 is offline   Reply With Quote
Old 11-03-2020, 09:43 AM   #53
geezer#99
geezer#99's Avatar
Re: 1980 smog
Yes!
Egr on front of intake on bbc.
Like this 73 vette intake.
Truck one might be different.
I’ll keep searching for a pic.
Your estimate to make it Pass smog Will likely be doubled by the time you’re done.
Likely not worth it.
Another problem is you’re trying to match up smog devices on a 454 using a 350 label. Likely not even close to the same.
https://www.corvetteforum.com/forums...ke-gasket.html
Old 11-03-2020, 10:48 AM   #54
geezer#99
geezer#99's Avatar
Re: 1980 smog
Here’s a good reference motor pics.
Give you some ideas of what you need.
https://losangeles.craigslist.org/ws...221997640.html
Old 11-03-2020, 11:03 AM   #55
Rickysnickers
Re: 1980 smog
So then his big block would need to be of 1980 or newer origin.
If I read that right.
Yes, that's correct. The same year of the current vehicle or newer. Older engines are not allowed.
Old 11-03-2020, 12:22 PM   #56
malc1080
Yes I got lucky that my 1980 is a california smog truck and the 454 is also California smog and came off the same year. I got saved since they put the RPO sticker of the donor in the glove box. That’s my proof that it’s also an 1980 and was equipped with california emission. Just have to take off all the “hot rod” parts.
Old 11-03-2020, 12:24 PM   #57
malc1080
Yes thank you for that reference’! My 454 will look like that when I’m done
Old 11-03-2020, 12:37 PM   #58
geezer#99
geezer#99's Avatar
Re: 1980 smog
I’m not doubting your info but motors get changed all the time.
Do you have the info from the flat pad in front of the passenger side head.
That info will confirm your motors origin.
Old 11-03-2020, 01:39 PM   #59
malc1080
There is no flats in front behind the alternator. Tried looking and I can’t find anything. I think I’ll have to crawl underneath in a bit to confirm. I had doubts too
Old 11-03-2020, 01:57 PM   #60
geezer#99
geezer#99's Avatar
Re: 1980 smog
Not on the head, on the block. Right at the point where the head bolts onto the block.
Info here on suffix code location.
https://www.crankshaftcoalition.com/..._Chevy_engines
You might need to swing your alternator over to see it.
Old 11-11-2020, 11:17 PM   #61
Loco83
Loco83's Avatar
Re: 1980 smog
Don't know if this will help but this is my 83 with the 305.
Loco83 is offline   Reply With Quote
Old 11-11-2020, 11:49 PM   #62
malc1080
Thank you loco. You and a few others are regulars to all my questions. Always helping me out. Thank you. Yea I might not be able to find what I’m looking for. I’m stuck with passing it dirty I guess. Tired so hard to do the right thing. I thank my idol Arnold for removing the rolling 30 lol .. he’s still a badass and legend ! Lol
Old 11-12-2020, 08:18 PM   #63
donw1986
Re: 1980 smog
My 86 still have all smog on it air tubes, diverter valve feedback carb, air pump, heat riser
donw1986 is offline   Reply With Quote
Old 11-12-2020, 09:16 PM   #64
malc1080
Thank you for the help! But unfortunately I’ll have to remove the 454 and put back a 350 same year or new if I want it to pass smog legally. 454 wasn’t an option so state ref said they will not approve it.
