Old 11-03-2020, 10:20 AM   #1
ubtripn
ubtripn's Avatar
Do I need to install an electric fuel pump
I am running a mechanical fuel pump right now with a Holly carb on an engine with 350 HP output. Do I NEED an electric fuel pump to improve performance? Thanks all.
ubtripn is offline   Reply With Quote
Old 11-03-2020, 10:38 AM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Do I need to install an electric fuel pump
No. I run a Holley mechanical in a 550 + 496 bb in my Chevelle never had a fuel starvation problem . I did however put larger fuel lines from the tank to the pump
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-03-2020, 10:40 AM   #3
geezer#99
geezer#99's Avatar
What does improve mean?
Your motor only needs a little fuel. Higher pressure or more volume isn’t really needed.
geezer#99 is online now   Reply With Quote
Old 11-03-2020, 11:11 AM   #4
Rickysnickers
Rickysnickers's Avatar
My vote would be to save your money and stay with what you have.
Rickysnickers is online now   Reply With Quote
Old 11-03-2020, 01:19 PM   #5
ubtripn
ubtripn's Avatar
Improve would mean make better in some way, thanks all for the advice, it seems to be just fine, 8lbs but the gauge I installed before carb bounces so there is that but it runs fine. Thanks again.
Old 11-03-2020, 01:32 PM   #6
geezer#99
geezer#99's Avatar
Have you tuned for altitude?
Jet leaner and optimize your timing?
Old 11-03-2020, 04:15 PM   #7
ubtripn
ubtripn's Avatar
oh yeah, just thought there might be other imperatives I was unaware of.
Old 11-03-2020, 11:26 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
The fuel pump has poppet valves in it, so pulsing in the fuel pressure is to be expected.
~Steven
Simi Valley, CA
Old 11-04-2020, 10:58 PM   #9
ubtripn
ubtripn's Avatar
Got it, thanks all!
Old 11-07-2020, 11:19 PM   #10
57larry
nope
57larry is offline   Reply With Quote
Old 11-08-2020, 08:45 AM   #11
Barnfind46
Barnfind46's Avatar
The only time you need an electric fuel pump with a stock-ish carb setup would be with 10% ethanol fuel and hot weather. The ethanol makes the fuel tend to vapor lock. Even with only 7 psi the fuel is under pressure and helps protect against vapor lock. I lived in North Texas and would drive to work in the morning no problem. Headed home at 4 and the truck would quit half way home. Cooled down and started right up. Added the pump and covered the fuel lines and problem solved.
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
