Old 11-04-2020, 10:40 PM   #1
msg
66 C10 Rewire questions with American Autowire kit - 500560
Never rewired before and heard it was super easy with this kit. So I bought it and then I read the instructions that Ill be stripping and crimping a bunch of terminals on wires and that each terminal I install should be properly soldered. Ive got a few wire crimping tools but nothing like what they show in their video.
https://www.youtube.com/watch?v=8u_EkMsioMY
Those of you who have done this, did you have or buy hundred dollar crimpers? And on each crimp of a terminal did you solder?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 11-05-2020, 12:56 AM   #2
REDROCKER652002
Re: 66 C10 Rewire questions with American Autowire kit - 500560
My son and I did his 69. My advise, rent the crimpers they have. They will make a huge difference in how well you get the wires crimped and how well the connections fit into the plugs and bulkheads. I tried it with a regular crimper and screwed a few up before I decided to get the tools they have. Get both sizes, they allow you to rent them for 30 days I think it is. And if you need more time all you do is call them They were great with me when I ran into a few self caused problems. Super easy setup if you ask me, and I had never done anything remotely close to that before. Get their tools and you will save yourself a bunch of headache. Just my .02.
REDROCKER652002 is offline   Reply With Quote
Old 11-05-2020, 07:54 AM   #3
notsolo
notsolo's Avatar
A barrel terminal crimping tool does a decent job....$16....soldering is not really needed IMO....would be good on larger wires.
notsolo is offline   Reply With Quote
Old 11-05-2020, 08:49 AM   #4
nsb29
nsb29's Avatar
I used the crimpers I had but soldered all the terminals as I have even factory crimped pull apart why take the chance
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 11-05-2020, 09:00 AM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
I've hardly ever soldered terminals in my past life. Over the years I have purchased a few crimper styles, ratcheting etc. Their all good and not one is perfect for every crimp or terminal. Ya you can do it with one, I have.
Brass terminals tend to be softer in the hold department, so that may be why they recommend soldering. Don't go cheap here, do as they say.
Old 11-05-2020, 09:09 AM   #6
msg
I'll call them today and ask what the cost of renting the recommended tools are. In the video they show the terminal crimped but I didnt see it soldered. Thats only once its slid onto the post of the component? Not an electrician so I assume a terminal is that point.
Old 11-05-2020, 09:33 AM   #7
msg
I called and spoke with them and the guy I spoke with was confused as to why soldering would be needed and apologized it was in the instructions and told me not to solder there was no need. The 2 F type crimping tools to rent in the end would be $50 for 30 days. You buy them at full cost but if returned before the 30 its $25 each tool and he said I needed 2 different ones. One to do a single style connection and one for multiple wires into one like for headlights.
Old 11-05-2020, 10:00 AM   #8
MT65
I have wired more cars than I can count, American Auto Wire is the best out there, that’s why I am a dealer for them. If you solder, I can tell you exactly where you will have an issue, the terminal thats soldered, the soldering hardens the wire at that point and it becomes brittle, check the testing BMW did years ago on this.
I have at least 4 pairs of crimping tools, each for their own style, if youhave one that only squeezes the terminal and doesn’t stake it, your gonna have problems, use a good adhesive lined heat shrink, never rely on the blue, red, yellow plastic crap, they don’t seal anything. If your interested, I will take pictures of my crimp tools and send them to you...
MT65 is offline   Reply With Quote
Old 11-05-2020, 10:09 AM   #9
msg
so this type crimper would be a no no?
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11-05-2020, 10:30 AM   #10
msg
Instructions
Old 11-05-2020, 03:12 PM   #11
MT65
Those work for a lot of the packard style connections that the factory used, would not be my choice for ring terminals, it reads for insulated, because it just squeezes the plastic insulation on the terminal, I don’t use any of those, I use all bare uninsulated terminal, the follow up with an adhesive lined heat shrink.
Ill take some pictures this afternoon and see if I can get them up, mind you, this is what I use, not every person is gonna have the same take, I just don’t want problems with terminal failure...
Old 11-05-2020, 03:25 PM   #12
roll_the_dice
roll_the_dice's Avatar
I am almost finished with my wiring job..only thing left is the rear tails lights...same kit. I was lucky and a buddy of mine had the crimpers from AAW so I borrowed them. Before I knew that though, I bought a pair of the smaller crimpers used on Ebay for about $35 delivered...I plan on doing more cars, so I will be purchasing a set of good crimpers for future use... and I did not solder anything.
roll_the_dice is offline   Reply With Quote
Old 11-05-2020, 03:34 PM   #13
The Rocknrod
Moderator
Instructions
There are various jaw inserts for that tool that will give you the correct crimp, that tool's jaws is not one of them.
Old 11-05-2020, 07:14 PM   #14
msg
I ordered it but looks like a return. If there is a crimper that isnt very expensive that will work for whats needed please pass it along. If Im in for $50 plus I guess the shipping to AAW then I wouldnt mind investing is a tool to keep. Its likely that the one that I need is just too expensive.
Old 11-05-2020, 07:41 PM   #15
MT65
These are some of the tools I personally use, the pictures with 3 have the terminals they would be used for and the single is for the terminals pictured with it, it happens to be a Klien, the others are marked made in usa, possibly ones I got from American Auto Wire...hope this helps
Old 11-05-2020, 08:40 PM   #16
PGSigns
PGSigns's Avatar
When I did the first truck with AAW I bought the crimpers they have off ebay. They guy bought both pairs and sold them when he was done. I do a lot of work on cars and trucks so I always just buy the tools I need.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-05-2020, 11:28 PM   #17
msg
Much appreciated!
Jimmy
I do hope to buy and own, Ill snoop on ebay. Thanks.
Old 11-06-2020, 02:04 PM   #18
theastronaut
theastronaut's Avatar
It's best to not solder automotive wiring due to vibration. Check out HP Academy's free intro to motorsport wiring before you get started on your truck, it has a lot of great info. I wish I'd found something like this years earlier.
https://www.hpacademy.com/introduction-to-wiring/
We have these and have done multiple AAW installs with it.
https://www.amazon.com/Tool-Aid-1896.../dp/B006O1Y1FY
theastronaut is offline   Reply With Quote
Old 11-06-2020, 04:17 PM   #19
REDROCKER652002
My suggestion, take your time, have a cold beverage or two of your choice, and have fun with it. My son and I did it all in a few weekends, and I really went slow. The only place I encountered issues was at the starter and the gas gauge. I did not allow enough wire to the starter, and when he went to a header set up, he had to do a bit of rerouting of the battery, ignition and alternator wires. The gas gauge is a ground issue I believe, but I have told him to run grounds and he has yet to do it Other than that, make sure you have a good connection and just take your time. The instructions are easy to follow if you just sit and read each bag before you open it and start fooling with it My email is Redrocker652002@yahoo.com if you have any questions. If you are interested, I can give you my text number so you can text me while you are at it if you run into any questions. The 66 may be slightly different than the 69, but the basics are the same. Good luck, and I recommend a good IPA as a beverage. LOL. RR
Old 11-06-2020, 05:57 PM   #20
clemsonteg
Which set(s) of jaws do you typically use from this set with the AAW kit?
clemsonteg is offline   Reply With Quote
Old 11-06-2020, 08:23 PM   #21
theastronaut
Top left set in the Amazon pic.
Old 11-06-2020, 10:53 PM   #22
msg
Much appreciated Astronaut, I may buy this and return the AAW tool set I bought today at Summit. Drove 2.5 hrs round trip to do it. I thought I would get started this weekend wiring and that I would need the tools to get going. If you have had good success with the Amazon kit I will look into it tonight and the tomorrow watch the video you sent the link to.
Im actually trying to figure on the best sequence of what to do next. The engine is in but the quadrajet is not installed and connected to anything yet. The fuel tank isnt installed yet it will be in the cab and needs to have the electric fuel pump sone as well. The transmission and fuel lines need to be formed and installed. Steering isnt in yet. I have been working on the instrument cluster to get it done and thought it would be best to get that in and wired up before I put a steering column in the way. The Vintage Air AC needs to be installed but I thought that would be best after the engine is closer to being ready to fire up. So in all of this I though the wiring would be the right next step.
Ill include a few pics of where I am and if anyone has any thoughts on what is the right order please let me know.
Thanks Redrocker for the tips and the offer on help!
Old 11-07-2020, 08:38 AM   #23
roll_the_dice
I would also recommend doing as much wiring under the hood before you start putting inner fenders and pieces back on. Much easier to get everywhere with nothing in the way. The only things I really had to wire once my truck was back together was the wiring harness for the headlight and park lights.
Where in GA are you again? I am in Savannah.
Old 11-07-2020, 09:45 AM   #24
msg
Yeah I thought that before I bolted up all the fender panels and radiator support that the wiring and fuel line install would be easier having the room. But I would have to have the radiator support in in order to run the transmission coolant lines that need doing. I guess I can spend today with the first bag in the kit and see how far I get without doing any crimping. I did order the kit the astronaut suggested to save a hundred bucks. Im sure Ill need something else from Summit in the next few weeks, another drive. Im in Newnan GA about 4 hrs from Savannah.
Old 12-22-2020, 10:25 AM   #25
roll_the_dice
Hey MSG...did you buy the crimpers theastronaut recommended from Amazon? If so, did they do double crimps (for lights) as well as single? I have a single crimper and borrowed a double crimper from a friend, but want to have a good set of double crimpers for future wiring.
