Th400 not going into third
So I had a thread on here talking about not being able to shift into third with my th400. Some one said it could be my modulator. One thing I do know is I only have a vacuum hose connected all the way up to my intake mana fold. no hard line. My question is can I just make a hard line out of brake line and vacuum line at both ends? Also some one asked if I over filled it and I think it might be a half quart to a hole quart over. This tranny sat for almost ten years but ran fine when we pulled every thing. please help. Thanks in advance!
70 custom10 swb fleet side 454 th400 |
#2 | |
The Older Generation
Re: Th400 not going into third
You can use any kind of hard line. Steel brake line, copper, copper/nickel, or stainless. Shifting problem could also be that the linkage has moved and is out of adjustment. Block the wheels, loosen the clamp bolt on the shift rod under the hood, manually put the transmission in park, have someone hold the shift lever in the park position and re-tighten the clamp bolt. See if that changes anything. LockDoc
![]() Join Date: Aug 2020
What Leon stated.
Replaced my modulator, took 12 bucks and about 15 minutes. Adjusted the rod properly and spot on. A adjustable modulator can help with shift points. Having the rod set proper is the big thing. PO had it all out of wack and set to shift at way too high rpm and at 3 g's. |
#4 | |
If the modulator is wonky it sometimes won't shift up to 3rd until its really way past reasonable or not at all.
I may have missed it but have you dropped the pan and changed the fluid n filter?. By no means a tranny expert but a valve in the body could also be gummed up and syuck |
#6 | |
#7 | |
That will be a good start. Hope that cures it. I had a leak in the vacuum line on my TH350 and when it was cold and you put it in reverse it would kill the engine. once it got warmed up it worked fine. Sometimes you run into some strange stuff with them. LockDoc
Where do you guys plug your modulator vacuum line on the other end? in the carburetor or the intake?
![]() Join Date: Apr 2016
On the intake, on a vacuum tree, behind the carburetor. In 1969 there were only 3 ports on the Quadrajet carburetor and they were occupied by the heat stove valve, the distributor, and the choke pull off. The TH400 and air conditioner vacuum ball get their vacuum from the intake vacuum tree. That's my 2¢.
