Quadrajet Carb gettin' place
Can you recommend who/where to buy a quality rebuilt quadrajet carb for a '81 K20 350
Need to pass smog so has to be matching part number jetting, etc Im pressed for time so, R&R, I will rebuild my old one later. Usually some rebuilds redo the loose throttle plate shaft with bushings anyway I have a couple old old links Recommendations please...Thanks Again , The carb has to have the same jetting so I can pass emissions test
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
Re: Quadrajet Carb gettin' place
SMI Sean Murphy Induction great qjet guy! Sorry dont have web but a search should bring him up in Cal.
location?
I have had a couple of quadrajets rebuilt here over the past 25 years with good results.. being in socal, I'm sure they can set you up right https://jetchip.com/contact/ ask for Johnnie ![]() his work is published in several articles and they catalog carbs outright at summit, jegs, etc. good luck!
I started out with nothing - and I still have most of it |
#4 | |
Suvile, is Your QJet from Sean on a daily driver or race? , Im moving back to Idaho in a couple months . You like mountain home? I used to live in Sandpoint area and Emmett .
#5 | |
I thought that was odd. .
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting Last edited by GSP7; 11-18-2020 at 05:32 PM. |
#6 | |
![]() everything since they've done for me are smog exempt so never discussed it with him.. there's some specific models listed on top of this list; https://www.jegs.com/vpt/JET-Performance/Carburetor might get real close to what you need with more detail search there or summit, etc.. although not a smog tech, or ever been one, I do supervise them at work and I'm the station manager for my larger shop.. we're captured fleet and don't have anything carb'd.. but who is telling you the jets, casting numbers, etc. are scrutinized for your inspection? BAR inspector? get flagged as gross polluter? I've got a lot of friends in the biz here in socal.. if we knew where you were might be able to turn you on to a local shop that could of take care of you.. good luck!
I will most likely have to just use my original carb and take the time, have done time, and rebuild it my self
Ive done several in the past. The jets and rods have to be the exact same size number as whats in mine to pass smog test.... I know because I had changed them Living in Idaho when I put the new motor in, and later In Ca it wouldnt pass Ca smog test . I had to do research years ago to find exactly what sizes were in my truck, find them in my Qjet parts box, and put them back in. Then it passed smog again
I will throw this out for you here.
MSD makes the Atomic fuel injection tbi carb legal. |
I have an SMI Quad on both drivers a C/20,350 and a C10,292 they work flawlessly
