11-25-2020, 06:05 PM | #1 |
Misc. Parts someone should need
Misc. Used 67-72 Parts. All prices plus shipping cost. Located in Shelburn, IN. For sale on other sites. Post to thread as per rules. I only accept PayPal and postal money orders
Small block engine stands. Grease included $45 S/B balancer bolt with washer $5 S/B dist hold down clamp $5 Inner fender to cab bolt with large washer $7 each 67-70 rod style throttle pedal arm (rusty but solid) & hold down $11 Wiper motor to linkage crank arm no clip $8 Brake pedal to rod shoulder bolt and nut $6 Upper 3 core radiator hold downs with rubber cushion $16 pair Power steering pressure hose (used unknown condition but looks ok), P/S return tube off of gear box and frame hold down clamp with bolt. $25 all Steering column to dash cluster trim $11 Steering column to pedal assy. Bracket $11 Steering column to firewall bracket with clamp $15 Auto steering column linkage with frame bracket (everything used with some wear) $38 Pedal assy brace with pedal stops $7 Used Mounts and bolts for standard shift transmission bell housing mount $22 Parking brake parts from a long bed rear coil spring suspension frame: Left side rod with cable slide $15 Intermediate cable $10 Inter. Cable to rear cable connector clips $11 pair Cable slide at front cable connection $8 Cable support hooks $11 67-68 parking brake handle cover $22
Note: All parts I have for sale are also for sale locally. I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts. |
11-25-2020, 06:45 PM | #2 |
Re: Misc. Parts someone should need
I will take the sb balancer bolt with washer shipped to Pa 17517
11-25-2020, 07:52 PM | #3 |
I will take the shift linkage
11-25-2020, 09:37 PM | #4 |
I could use a fender bolt with the big ass washer and the 67-68 parking brake cover. Can you pm total with shipping to 83646? What’s the condition of the transmission mounts?
1968 GMC C2500 Long Bed Fleetside |
11-25-2020, 10:16 PM | #5 |
Shipping is $6.05 USPS first class mail or $8.00 USPS priority mail so your total will be 11.05 or $13.00 depending on which shipping you want. Let me know. Thanks.
11-25-2020, 10:23 PM | #6 |
Ok, Thanks. I will need your shipping zip code to figure shipping cost. Thanks.
11-25-2020, 10:56 PM | #7 | |
The bell housing mounts look like good used condition to me. The total for the fender bolt, handle cover and bell housing mounts is 66.05 shipped USPS priority mail.
11-25-2020, 11:01 PM | #8 |
Cover picture.
11-25-2020, 11:58 PM | #9 |
11-26-2020, 12:09 AM | #10 |
11-26-2020, 11:04 AM | #11 |
$12.25 USPS priority mail so a total of $50.00. I will PM you payment method. Thanks
11-26-2020, 11:08 PM | #12 | |
11-26-2020, 11:30 PM | #13 |
Ok, PM sent with PayPal info. Thanks
11-27-2020, 10:00 AM | #14 |
How much for all the steering column brackets shipped to 30276
11-27-2020, 11:17 AM | #15 |
Paypal sent! As I said in the PM, I only need one fender bolt.
Thank you!
11-27-2020, 05:58 PM | #16 |
These pieces or do you want the trim? $42.30 for what is pictured including USPS priority mail shipping. Or $32.30 for just the brackets without the dash trim filler including the shipping.
11-27-2020, 07:46 PM | #17 |
11-27-2020, 08:18 PM | #18 |
$51.00 shipped for all parts previously pictured and this bracket.
12-10-2020, 09:30 PM | #19 |
Pictures for Cericd.
12-11-2020, 03:22 PM | #20 |
Todd,
I assume the shift linkage sold??? Do you have any more (a complete set?) Thanks Jeff |
12-12-2020, 12:00 PM | #21 |
I know I have parts but I don't think I have another complete set. I will check when I get time. Thanks, Todd
