Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 11-30-2020, 11:01 PM   #1
papsoldblue72
papsoldblue72's Avatar
Question Rear end help...
I need some help my father is looking for a 8.5 rear end for his 67 chevelle ... he said his measured 60 inches from hub to hub wheel mounting surface that is .... did some of the s10 blazers have a 8.5 about that width? If so what years do I need to strip it from? Thanks in advance...
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 12-07-2020, 11:23 AM   #2
Myself
Re: Rear end help...
The standard 4x4 S10 rear is 59". Most are 7.5 rear gear. Look for a '96-up loaded 4x4 (NOT ZR2 offroad package...they're 63"). Then look for the axle tubes to flare up a bit bigger right before they enter the pumpkin. That's the 8.5 rear. The common 7.5 rear has axle tubes the same size all the way into the pumpkin.
Myself is offline   Reply With Quote
Old 12-08-2020, 07:19 AM   #3
b454rat
Is he going with ladder bars or a 4 link? Chevelles use trailing arms, the mounts are molded into the center, those aren't on the S-10 axles.
