Old 07-06-2004, 02:59 PM   #1
Tom
driving is in my blood
Tom's Avatar
Fillin the gas tank
Just thought I'd share: I, like many others with 73-87's, have problems filling my gas tank correctly. On both my truck its always taken me sitting there holding the filler the entire time, just just the tip in and pointed strait down as much as possable. Such a pain.
The other day my friend put the filler in, only puts the tip in, but then leaves it hanging and puts it on auto easy pump. Not only did it pump, but it let the truck take almost 2 gallons more then it ever has.
Anyone else have some neat trick to get it to fill easier? Anyone know why our trucks are like this?
Old 07-06-2004, 03:16 PM   #2
apstguy
LED King
apstguy's Avatar
For some reason, my truck only does this in WINTER. Why I don't know. The nozzles with the rubber acorian covers DO NOT work on these trucks. I have to go to stations that have the straight metal nozzle. I can empty a tank and I still only get 14 gallons in it.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 07-06-2004, 03:19 PM   #3
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
My truck did that shortly after I had a wreck. Upon removal of the tank to replace the sender I found that the vent tube had broken off of the tank. (the one which vents back into the filler neck) When I fixed it with some JB weld, the problem went away. Just something to check.
NeCrOmAnCeR is offline   Reply With Quote
Old 07-06-2004, 03:56 PM   #4
SanitysBane
its because of the 90 degree bend and the almost flat secion into the tank
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 07-06-2004, 05:33 PM   #5
TIMSPEED
TIMSPEED's Avatar
Same here Tyler, ONLY the ones WITHOUT the rubber boot work, and the MOST I can ever get in, is 14 gallons. Usually, the only place that has the metal tube only are shell which is the HIGHEST.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 07-07-2004, 12:32 AM   #6
apstguy
LED King
apstguy's Avatar
Beacon (names now changed to Valero) has the metal nozzles and are cheap.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 07-07-2004, 11:21 AM   #7
Destructo
I run my 16 gallon tanks dry and get just over 15 in mine. If I don't watch it sometimes a little gas will splash out also, but I can stick mine about half-way in and lock the handle and leave it hanging and it will work fine.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 07-07-2004, 12:38 PM   #8
1970c10sb
my 76 has this same problem u guys speak of. My past trucks, 78 and 81 never did this. is there a fix for it? i always thought it was my "custom" filler neck.
1970c10sb is offline   Reply With Quote
Old 07-08-2004, 01:33 AM   #9
chevychic
chevychic's Avatar
I don't have this problem. Oregon has a no pump law meaning that you can't pump your own gas. But it never fails that they put the nozzle in, set it for auto fill, walk off, and 5 seconds later it clicks off. I can always tell the guys that own older chevies. They're the ones that put just the tip of the nozzle in so the gas flows smoothly without backing up against the fill tube.
ChevyChic
86 Chevy K-10
If I can't be a good example, then I'll just have to be a horrible warning.
"You're braver than you believe, and stronger than you seem, and smarter than you think"
- Christopher Robin
chevychic is offline   Reply With Quote
Old 07-08-2004, 05:45 AM   #10
1974StepSide
Play it Loud...
1974StepSide's Avatar
I can never leave the nozzle alone, I have to hold it sideways and forget about using the auto-fill lever. Could it be because I have a stepside? And the two times that I've run out of gas, I filled up with 12 gallons??? I know that is weird for having a 16 gallon tank!
Big Moe
1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint.
1952 Chevy Pickup waiting to be brought back home!
1974StepSide is offline   Reply With Quote
Old 07-08-2004, 09:44 AM   #11
screwballl
Tonawanda 454
screwballl's Avatar
i have stock filler neck and have the same problems...i usually get 20 gals or so in mine so im not sure what size tank you guys have or if you arent letting it run down further...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 07-09-2004, 03:12 PM   #12
76bonanza
76bonanza's Avatar
I have dual tanks all stock and do not have any problem at all ram it in autofill.
In fact mine fills tell it spews out on the ground before it stops.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-09-2004, 03:53 PM   #13
kballan
kballan's Avatar
When I got my '86, the gas tank had a leak in it. I bought a 20 gallon tank, and used the original filler neck with no problems. I don't know if the venting is different because it's a bigger tank, but even with the gas nozzles with the rubber covers, I had no problems at all.
Kent Ballan
ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP!
kballan is offline   Reply With Quote
Old 07-09-2004, 09:03 PM   #14
86 Red_Bowtie
86 Red_Bowtie's Avatar
I have no problem filling my gas tank on my 86 just put it in click it on and way it goes when it clicks off i can usually put another gallon or two more in the tank.
86 Red_Bowtie is offline   Reply With Quote
Old 07-09-2004, 10:23 PM   #15
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Arrow
Alot of the times it wont shut off for me, spraying gas out everywhere. Then if both tanks are dry, trying to turn the truck around to get to the empty tank. Most of the pumps around here wont let you fill up again using the same credit card, so you have to ask someone to hold the nozzle for you when you make the u turn around.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 07-10-2004, 07:32 AM   #16
Destructo
I normally just fill one tank up at a time on my truck, unless i'm going on a long trip, too much hassle to fill both up at once for me and if i'm by myself is hard to find somebody willing to hold it for ya.
Old 07-10-2004, 11:41 AM   #17
86 Red_Bowtie
With the price of gas now days you have to be rich to fill both tanks of gas at one time.
