#76 |
![]() Join Date: Sep 2003
Re: The build date project
1970 Chevrolet
#77 |
This 71 chevy is already listed on post #2, but here is more accurate date. 12/10/70
#78 |
1970 Chevrolet
#79 |
71 chevy
1Z655380 5/71 With the rare band-aid option |
#80 |
1970 chevy
0B152770 5/70 |
#81 |
All about them K’s
![]() Join Date: Jun 2014
All from yesterday and today added except for 2 GMC’s that I need to figure plants out. Thanks for the leg work 402bowtie!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#82 | |
Does this link help on the gmc plant question you mention? |
#83 | |
All about them K’s
#84 |
All about them K’s
GMC’S added. Tomorrow I’ll get to the PM’d info I’ve got and what ever else comes up here.
#85 |
Couple more I found today.
In picture order: 72 chevy Blazer--2F166599; 4/72 72 chevy suburban--2F156196; 3/72 70 chevy Blazer - reproduced sticker (restored Blazer), 0S145151; 1/70 72 GMC - 2F710613; 5/72 72 chevy - 2S175704; 4/72 Last edited by 402Bowtie; 12-08-2020 at 12:28 PM. |
#86 |
![]() ![]() Join Date: Feb 2009
This is really turning out, thanks for the effort. Still can't zero my 72 Fremont 146xxx down to a single month, but pretty close. Fremont was really pushing them out too, they may have approached 9K a month at the time.
Any chance 71/72 Chevy Fremont trucks were the most plentiful? ![]() Without specific dates you can't tell how many were produced per month, but here's where my 72 C20 would fall for Fremont, as a guide.......146xxx would be Feb. or Mar. 135708 Jan. 153077 Mar. Increased by 17369 161544 April Increased by 8467 164046 April Increased by 2502 168790 May Increased by 4744
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 12-08-2020 at 02:26 PM. |
#87 | |
#88 |
All about them K’s
Personally I wonder if it’s more that the Fremont trucks were being mainly sent to dry climates being they were produced in the west, and are the ones that have better survived.
I’ll get on the additions this evening. Also, the original thread has been closed.
#89 |
It may be helpful to reference the source of the info when updating the first two threads. For example, noting if it came from a PM or which post # the info is pictured.
Here's one I found that may be slightly out of order with another data point (post #68). 72 chevy 2Z163961 I believe build date shows 4/28/72 |
#90 |
1970 GMC St Louis truck
1970 chevy Tarrytown Last edited by 402Bowtie; 12-08-2020 at 05:51 PM. |
#91 | |
![]() Join Date: Apr 2005
If so, these are the first two I remember confirmed from the same day. Last edited by geunther; 12-08-2020 at 06:26 PM. |
#92 | |
Does anyone know how the "job sequence number" (see very top left of build sheets) impacted production? The truck in post #68: Serial Number: 2Z164046 Job Sequence Number: 03114 The truck in post #89 Serial Number: 2Z163961 Job Sequence Number: 03x09 (guessing 03009, or less likely 03809) It is interesting that even though the serial numbers are 85 numbers apart, the job sequence numbers appear to be at least 105 off from each other. I'm wondering if it is possible that a certain batch of serial numbers started on a given day and then received their production date when finished assembling. If there were multiple assembly lines, perhaps some lower serial numbers could actually have a slightly later assembly completion date. ...just thinking/guessing out loud. Last edited by 402Bowtie; 12-08-2020 at 07:18 PM. |
#93 |
All about them K’s
Awesome work guys, that’s a great first milestone.
#94 |
These are from an old thread on the board. Most on that thread appear to already be captured within the first two posts here or have illegible pictures.
70 GMC; SZ68109; 3/70 70 chevy; 0Z142486; 2/70 70 chevy; 0S138xxx; 12/69 70 chevy; 0A158364; 7/70.....this one was already on the list but had incorrect date. 72 chevy; 2F355033; 3/72... Original decal and reproduction decal found at link above. Last edited by 402Bowtie; 12-08-2020 at 09:36 PM. |
#95 |
#96 | |
There were I think 603,347 Chevy trucks (Blazers, C10s, K20, suburban, etc) produced in 1972 (according to post #6 in this thread...I added up all the 1972 production numbers). It appears Flint produced close to half of those 600,000 Chevy trucks based on the serial number referenced. In other words, Flint produced the 255-thousandth Chevy truck in March of 1972, and production likely went into June or July. Last edited by 402Bowtie; 12-09-2020 at 02:15 AM. |
#97 |
All about them K’s
Added today’s, I started adding post numbers to the entries. I will go thru and update the rest of the entries as I get time. I still need to add a pm list I’ve got, hopefully tomorrow.
#98 |
Piecing together post #7 in this thread states that his 1970 Blazer s/n would be 0S138946 with build date of 12/69.
On a related note, both of the first two posts in this current thread mention that Blazers and Jimmy's don't follow the same truck sequence. I see that many (all?) 69 blazers started with a "B," but are there any more details regarding that sequence comment? I would think the last 6 s/n digits are chronological (per plant), regardless if Blazer, suburban, or truck. No? |
#99 | |
Looking at March numbers for the other plants, Flints numbers would have to be about 71% higher. But if Flint produced half of the entire 72 run, this percentage would make sense. However, we do have a Flint jamb sticker 4/72 with a sequence of F163780. I have added the F355033 and will continue to try and reconcile this. |
#100 | |
