Old 12-09-2020, 10:28 AM   #1
nsb29
nsb29's Avatar
Dumb question about rock guards
My question is what are the four dimples forName:  1D6AE9A1-2C33-412C-AACB-F583B7CA67AA.jpg
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 12-09-2020, 08:59 PM   #2
chtr65
Re: Dumb question about rock guards
Probably to add strength and reduce flex. Just my opinion.
chtr65 is offline   Reply With Quote
Old 12-10-2020, 09:30 AM   #3
nsb29
nsb29's Avatar
One dimple hits bumper braces so it doesn’t lay flat so when you try to bolt it down it distorts the rock guard
Old 12-10-2020, 01:58 PM   #4
BigElittleg64
BigElittleg64's Avatar
I do not recall seeing this before, where does it go on our style trucks, preferably a 1964 C10 LWB Stepside.
BigElittleg64 is offline   Reply With Quote
Old 12-10-2020, 02:55 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=785315
Old 12-11-2020, 01:12 PM   #6
BigElittleg64
Wow never knew about these thanks for the link.
Old 12-12-2020, 11:03 AM   #7
bigmoe
bigmoe's Avatar
On my truck I shimmed between the parts with washers in order to avoid that distortion.
bigmoe is offline   Reply With Quote
Old 12-12-2020, 06:33 PM   #8
nsb29
nsb29's Avatar
That’s what I did also just trying to figure out what the reasoning was behind them ?
Old 12-12-2020, 11:22 PM   #9
ray_mcavoy
I believe that is the purpose of those dimples ... to make contact with the bumper brace so it doesn't lay flat down against it. If they were flat down against both bumper braces, they would be slightly tilted in relation to the top edge of the bumper. The dimples cause the outboard side to be raised up just enough so the guard stays parallel with the bumper.
Also, the factory guards were stamped with an indentation surrounding the bolt hole on the side with the dimples. That allows them to be bolted down tight without any distortion. It appears as though the reproduction guards are lacking that indentation around the bolt hole and therefore requiring shim washers underneath to avoid distortion.
ray_mcavoy is offline   Reply With Quote
