Old 10-25-2020, 08:21 PM   #1
68PanelTruck
68PanelTruck's Avatar
What to do about area around gas cap.
Hi guys,
This is for a 68 panel truck. I will be replacing the rear quarter panels with patch panels but I don't think the patch panels will cover the area near the gas cap. I'll have a better idea when I have everything. I'm slowly getting the parts to do this but I don't know what to do about the gas cap area. I ordered the patch panel for the area behind the driver door, wheel arch, lower quarter and tail light area patch. I want to keep it in the stock location (not looking to move the cap) and stock looking so I guess I'll need to find an original panel with the gas cap area that's in good shape? Does anyone know what years and models will work? I'm assuming a Suburban would work but what years?
Same question for the rear marker lens holes. What year sheet metal will work 68 to ??? Can I use pickup truck sheet metal for the lens area ? I need to find a panel with a hole to mount the lens.
It's not rust, it's called patina
Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust.
68PanelTruck is offline   Reply With Quote
Old 10-25-2020, 08:24 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: What to do about area around gas cap.
Originally Posted by 68PanelTruck View Post
Hi guys,
I used a door skin to patch mine.
LockDoc
Leon
Old 10-25-2020, 08:26 PM   #3
68PanelTruck
LockDoc
What did you use for the gas tank filler area? What about the marker light area? I need to replace those holes.
Old 10-26-2020, 07:48 AM   #4
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Suburbans are the same in that area. Find someone like me that parts them out on a regular basis . Shipping can get expensive but it is still possible to find larger original sections
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 10-26-2020, 12:37 PM   #5
68PanelTruck
Yes, I've been watching the "for sale" section for that section. Would you know what years would work? I would think 68 to ??? Thanks for your help?
Old 10-26-2020, 05:03 PM   #6
richard2717
Send me your email address and I will show you what I have. 67-72 suburban and 67-70 panel are all the same in that area to my knowledge
Members I have met.
Old 10-26-2020, 06:59 PM   #7
68PanelTruck
Will do and thanks again.
Old 11-29-2020, 07:39 PM   #8
CG
BlahBlahBlah
Have you considered scavenging a filler and door from a donor vehicle? I think most people would never even know a filler door wasn't stock. It would be a good look with the rest of the sides of the panel being smooth too.
Old 11-29-2020, 09:48 PM   #9
notsolo
notsolo's Avatar
I used a fuel door from a 1990 S-10 2" fill....Cut about 18" x 18" out of the donor then trimmed as needed. Inset with Pneumatic flanging tool.
notsolo is offline   Reply With Quote
Old 11-30-2020, 06:54 PM   #10
68panelman
68panelman's Avatar
I always found it odd that GM went back with an exposed filler neck, and the 1955-66 had a fuel door.
68panelman is offline   Reply With Quote
Old 11-30-2020, 09:04 PM   #11
68PanelTruck
Yes, I am considering using a door with a remote handle to pop it open if I can't find a good original. It would be much easier, any junkyard would have one from a late model truck or car. I'd like to keep it looking stock if possible.
Old 11-30-2020, 09:06 PM   #12
68PanelTruck
Looks good! Flanging tool can even make curves.
Old 12-09-2020, 09:34 PM   #13
notsolo
notsolo's Avatar
Flanging tool was modified by me to make it slightly deeper, also I probably rounded over 1 edge.
Old 12-09-2020, 09:49 PM   #14
68PanelTruck
Thanks for your suggestion. I was lucky today and found a good used panel.
Old 12-11-2020, 04:25 PM   #15
Burb
Coordinator of Synchronicity
Burb's Avatar
just take it off ...
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 12-11-2020, 04:32 PM   #16
Burb
Burb's Avatar
and hide it
Rick
Old 12-11-2020, 08:02 PM   #17
68PanelTruck
Hey that's pretty cool! Nice work.
Old 12-21-2020, 04:55 PM   #18
Burb
Burb's Avatar
thanks ... my patina was extra thin in the gas cap area so it had to be replaced anyway and figured this would be different ... also decided to add charging to the other side
Rick
