Old 12-17-2020, 07:58 PM   #1
pwdcougar
pwdcougar's Avatar
Lifting a Suburban body
It's finally time to put the body back on the frame. The plan is to suspend the body and roll the frame underneath. Then the body can be lowered into position. The back of the body will be suspended by the arms of the rear portion of the rotisserie. The front portion of the rotisserie will be removed and suspended by the piers of concrete block and the board between them on a good set of floor jacks. My concern of course is suspending it this way. Any thoughts on if this will result in damaging the body? The board is a 2x10 on the flat with three 2x4's making a E channel.
This is the only way I could think of doing this besides using chains or straps bolted to the front of the cab.
Please any and all feedback is welcome
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 12-18-2020, 02:44 AM   #2
Average Joe
Average Joe's Avatar
Re: Lifting a Suburban body
Looks tip top to me. I love those jack stands! Will you be able to lower the front with those?
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 12-18-2020, 06:44 AM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That should work. The only thing I might add is maybe a shim or another piece of wood on the outside of the top door jamb to keep the seam from getting rolled or bent. Those dang bodies are pretty heavy. I built a gantry crane and used a 2500lb HF atv winch with a snatch block to try to pick up a rusty burb hull with the doors on it and no seats. It was not happy. I ended up removing the barn doors and front doors to get it off the frame.
Ryan
1969 Chevy milk truck
Old 12-18-2020, 08:51 AM   #4
pwdcougar
pwdcougar's Avatar
Thanks! I’ve had these stands for close to 50 years. They have almost a foot of travel.
Old 12-18-2020, 08:55 AM   #5
pwdcougar
pwdcougar's Avatar
Good idea on not rolling the top of the jamb. I’ll try running a saw kerf down the length of the top pieces of wood that the jamb can fit into.
Old 12-20-2020, 02:52 PM   #6
pwdcougar
pwdcougar's Avatar
Worked like a charm!
Old 12-21-2020, 06:17 AM   #7
Dieselwrencher
That's awesome!
Ryan
