12-21-2020, 12:29 AM | #801 |
Re: D52 Caliper Rear Disc Brake Brackets
Do you make rear disk brake brackets for a 10 bolt camaro diff?
Posted via Mobile Device |
12-21-2020, 10:54 PM | #802 |
60-66 Nut
Sorry, no I do not. All 6 of the rear disc conversion brackets I make are designed for the '64-'82 truck 12 bolt and '79-'87 truck 10 bolts.
01-14-2021, 03:18 PM | #803 |
Does anyone know where I can get the Powerstop AR8622XPR Astro rotors? Nobody seems to have them in stock. These are cross drilled and slotted
05-12-2021, 07:03 PM | #804 |
Has anyone had problems with the outer brake pad center lower edge rubbing on the brake rotor?
05-12-2021, 10:45 PM | #805 |
60-66 Nut
Yes that has happened several times over the years that I have been fabricating these due to manufacturing tolerances with the aftermarket rotors. The Astro/Safari rotors did not come from the factory with D52 calipers/pads. I have revised the caliper brackets 5 times and I can not move them out any more or the pads will be past the outer edge of the rotors. That is not good either. I assume others have just ground/sanded the pads for clearance.
06-27-2021, 08:24 PM | #806 |
60-66 Nut
Due to an increase in the cost of having my parts laser cut, I have been forced to raise my prices. I'm not making any more money, just trying to stay in business with these increases in my costs. Thanks for understanding.
09-11-2021, 07:53 PM | #807 |
I want to order a set of your c10 rear disc brackets for my 1977.
09-11-2021, 10:12 PM | #808 |
60-66 Nut
PM sent........
09-12-2021, 06:00 PM | #809 |
I sent a message but I dont think it went through sent my email
09-12-2021, 10:46 PM | #810 |
60-66 Nut
I received 2 PM's from you. The first had no reply from you. I replied to the second PM from you. I work 80hrs/7 days a week every week every month and I only have time to be here on the forum once a day after I am done working for the day. If you require a quicker reply, please send me an email to the address given in post #1 of every one of my for sale threads. I answer all emails multiple times a day.
12-30-2021, 10:51 AM | #811 |
Do you have any kits for K10 and be able to keep E-Brake?
12-30-2021, 10:32 PM | #812 |
60-66 Nut
Yes I do and have been fabricating them for over 7 years. Here is the for sale thread for them. I fabricate over 26 products for the '60-'72 GM trucks.
http://www.67-72chevytrucks.com/vboa...d.php?t=637489
03-17-2022, 07:15 PM | #813 |
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
03-18-2022, 12:38 PM | #814 |
about damn time
03-21-2022, 09:57 PM | #815 |
60-66 Nut
If it wasn't for my wife, it would never have gotten done.
