Old 12-21-2020, 12:45 AM   #1
chev-obsession
chev-obsession's Avatar
What shifter linkage with auto tilt column
I am adding a tilt column from a mid 70’s motorhome to my 65 c10. I need the shifter linkage from column to trans, and want to know what my best option is. Hoping to avoid after market stuff.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 12-21-2020, 10:38 AM   #2
SCOTI
SCOTI's Avatar
Re: What shifter linkage with auto tilt column
I would start w/a 69-72 as my source.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-21-2020, 11:04 AM   #3
chev-obsession
I was wondering if that era of truck linkage would work. I’m sure it’s been done before but couldn’t find anything in a search.
1965 c/10 swb
1969 c/10 lwb
Old 12-21-2020, 12:03 PM   #4
SCOTI
SCOTI's Avatar
I just put in a tilt auto column (pre-73/ignition switch equipped) where the original 3spd was. Since the frames are interchangeable (minor differences but they are the same in the area where the pivot hardware attaches) I would bet the later model parts will bolt right in place.
Mine is highly modded so I have no need for factory original stuff but I'll base my search using the 67-72 as my criteria.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2020, 12:04 PM   #5
SkinnyG
SkinnyG's Avatar
I made my own with 3/8" rod and two spherical rod ends. At least you know it will fit.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-21-2020, 12:05 PM   #6
SCOTI
SCOTI's Avatar
It's very likely that's what I will do.
I used a Lokar set-up on my dually for header clearance & after getting it thought.... "I could of sourced this stuff for a lot less vs. the price for a 'kit' ".
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-21-2020, 08:14 PM   #7
AcampoDave
AcampoDave's Avatar
Certainly cheaper to source your own parts to make a Lokar style linkage, but with Covid running rampant it's pretty nice to get it delivered with a quick call to Summit.
AcampoDave is offline   Reply With Quote
Old 12-26-2020, 12:02 PM   #8
64shortbox
64shortbox's Avatar
I bought a Lokar knock off kit off eBay - the rod from the steering column to the trans shift lever wasn't long enough so I bought a length of all-thread rod to make it work. I still didn't like seeing the all-thread rod so I grabbed a piece of stainless tubing from my work and slid it over the all-thread.
I still wasn't happy so I stole some ideas from other board members and added a suspended gas pedal from a 72 C-10 and grafted on a brake pedal from a 73 C-10. Now I'm happy - for now anyway.
64shortbox is offline   Reply With Quote
Old 12-26-2020, 01:11 PM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
So what is the measurement of the rod that is needed?
Old 12-28-2020, 09:04 PM   #10
64shortbox
64shortbox's Avatar
Master Chief,
I'm in Phoenix and won't be back to Commiefornia to measure the rod on my truck for a couple more weeks yet.
Old 12-28-2020, 09:10 PM   #11
The Rocknrod
Moderator
Originally Posted by 64shortbox View Post
Master Chief,
Thanks buddy. I'm out of state as well, I get it.
