12-25-2020, 04:43 PM | #1 |
Led headlight issue
Go ahead and tell at me for led headlights, I know, l know, but man they are a lot brighter. Issue is, after I installed them, only one worked. Cleaned up the ground, the one that didn't work worked and the other one quit. Cleaned that ground and it switched again. Any ideas?
Merry Christmas to all Jeremy |
12-25-2020, 06:22 PM | #2 |
Re: Led headlight issue
Electrical issues can be stupid easy or it can be like 'chasing a grimlin'.
Money well spent is a decent multimeter and time spent on youtube learning how to use it. I plan to put the led headlights in mine but haven't gotten there yet. First I would just triple check all connections are good and reground the one that stopped working. If you still have no luck unplug the headlight and test the leads to make sure you are getting voltage. Assuming you are running your ground to chassis you can check that as well with the meter. If both those check out your headlight went bad. If you dont have any voltage OR have too little you have a problem between the source and the plug. It could be so many different things.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
12-25-2020, 06:32 PM | #3 |
Do a search. I think I remember something about needing a different dimmer or flasher or something like that. I could be wrong though, been drinking for a good part of the day. LOL.
12-25-2020, 07:09 PM | #4 |
Is it possible you need 2 positives and negatives? I know LEDs are polarity sensitive and/or they won't work in series or parallel (and I think that depends on the lights themselves)
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
12-26-2020, 08:40 AM | #5 |
Each headlight is grounded from the plug. I am going to switch sides to see if that changes anything and check voltage tomorrow. Guess just go from there
12-26-2020, 09:29 AM | #6 |
Try a test. Run 12v+ from the battery to each light separately and see if they light.
12-26-2020, 10:43 AM | #7 |
Old member
First off the head lights are feed from the drivers side light plug for both lights. Make sure the old plug is connected good. Make sure you don't have the wires crossed up any where. LED's don't like wires being crossed.
Head lights don't need a different dimmer or flasher or something like that.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-26-2020, 11:49 AM | #8 | |
12-26-2020, 12:00 PM | #9 |
20' Daredevil (Ret)
Pretty sure LED turn signals need a different flasher. With the stock flasher, the bulbs flash on/off too rapidly. If I'm right about that....
OP, if you're not familiar with multimeters, they are fairly simple to use if you are just looking for voltage. Or you can check the basics with a test light.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
12-26-2020, 02:16 PM | #10 |
Old member
Depending on what lights you have check the way you connected them and that the wires didn't get crossed in the connector's.
A while back some one posted they had found the kit they used had the wires reversed in the head light plug-in. Head lights and turn signal's are 2 different system's so the flasher would have no effect with head lights. This is all depending on a stock unmolested electrical system in good order. Yes if you are running full LED you need flashers. If you only have rear LED you don't. Well you shouldn't. I ran brake lights for years with LED's with no flasher.
12-26-2020, 06:22 PM | #11 |
Would a new wire harness help any in his situation or a relay in the system? I'm asking , was wondering the same thing the other day.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327/4L60 |
12-26-2020, 07:04 PM | #12 |
I will check the voltage at the plug. They are original plugs, but the nearly 50 year old wiring with me hacking on it for the last 30 might be questionable. Also, the high beam light is on I matter if I hit the foot button or not
12-27-2020, 03:55 PM | #13 |
After screwing around with it for a while an remembering I hate wiring, I found the issue I think. Seems to be the ground. I will stop tomorrow and get a wire bus, run the grounds independent to the bus an then one ground wire. Should take out a lot of splices. Hope that does it.
12-28-2020, 01:23 PM | #14 |
Try testing them individually by connecting them directly to the battery with some jumper wires. Or swap them and see if the problem switched sides. Most of the LED headlight kits are Chinese made and cannot be trusted. You may have received a faulty LED. After you confirm they work then chase down your issue.
I am a tech nerd and love LEDs but have been let down by most of the aftermarket products. None of mine have made it over 2 years without burn out. Some did not work upon arrival. All were from reputable companies.
Made in America by Americans |
