07-07-2004, 03:24 PM | #1 |
How do you take the front rotors off on a 4x4???
I'm new to front solid axle 4x4's and was wondering what is involved to replace rotors? It appears its all part of the hub assembly.
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 |
07-07-2004, 04:14 PM | #2 |
The rotors are held onto the hub by the wheel studs. If you have a press use that, if not you can pound them out with a brass hammer. Once the studs are all out the rotor & hub should seperate. It may take a few taps with a hammer, but they should come off. If your replacing the rotors, make sure both mating surfaces are clean & smooth, put the studs in and tighten them up evenly. This will pull the new rotors onto the hub . If the rotor don't run true you may have to have them turned.
07-07-2004, 09:14 PM | #3 |
I wouldn't trust "pulling" them in with the lug nuts. Press/drive them in with the same procedure used to remove them. You will put undue strain on the threads by trying to pull them in.
