Old 07-07-2004, 08:38 PM   #1
sixty8chev
The Sauz
sixty8chev's Avatar
Loose Axle?
Just pulled the rear wheels off my old mans 69 and when i pulled the drums off i heard a weird clunk. I grabbed the axle plate and i can push it back and forth about half an inch. Ay ideas what might have let go in the rear end?
68 lwb 2wd (spread between 3 garages)
72 Burb - Flat Deck
92 Yukon 3" lift - 33's - the new bush pig
01 Sierra - Daily Driver (for now)
sixty8chev is offline   Reply With Quote
Old 07-07-2004, 09:48 PM   #2
crazy longhorn
Fabricate till you "puke"
Well, if its a 1/2 ton truck the c clip axles do have some end play.....1/2" would be excessive tho... you might look for worn c clips, center pin , & check the clip groove on the axle for wear. they will have approx 1/8" end play. Good luck,crazyL one more thought....side bearings on the carrier...
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-07-2004, 11:03 PM   #3
smitty62
smitty62's Avatar
Don't think there's anything wrong with it.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 07-08-2004, 12:16 AM   #4
sixty8chev
The Sauz
sixty8chev's Avatar
I wish there wasn't anything wrong with it, I'm the one that's going to have to fix it. But theres a definite loud clunk when you move the axle that's gonna have to disappear before the trucks back on the road.
72 Burb - Flat Deck
