01-09-2021, 08:40 PM | #1 |
Anyone help with a plan of attack for body panels
I need recommendations on a plan of attack to fix my rockers and floor pan. Looks like the PO added some patch panels at some point and riveted them in. I ordered inner and out rockers and also the floor braces. As you can see in the picture I only need the sections that hook into the rockers replaced. I write brushed everything just to see how far up the rust went. Luckily the entire braces dont need to be replaced which is awesome. I am wondering if I should just replace everything while I am doing it. The metal is good though. The inner rockers are shot though and small sections of the outters which both will be replaced. The floor pans look like they have been patched and sealed at some point, looking under my truck though the original flood boards only have a couple small spots that were eaten through, I used a hammer and the rest was solid. I'm not sure the best way to remove the floor pan patches. Again, the have been riveted in so any help with how to attack would be awesome. I knownits hard to tell from pictures but the floor braces are really solid from the cab mounts until about 3 inches from the inner rocker .
I guess what I'm asking is should I start from the floor braces out? Or should I put the inner rocker floor extension in and fitted, then the cab floor braces, followed by the outlet rockers, and then the floor pans? Everything metal wise looks really good other then some minor spots. My A pillars are good along with the kick panels. The passengers side isnt that bad and I will start with that first. Then move to the drivers side. Just looking for some suggestions from those of you that have done this work and what was best. I will take plenty of measurement and be certain before I cut and fit everything. Thank you. Last edited by LockDoc; 01-10-2021 at 10:47 AM. |
01-10-2021, 10:53 AM | #2 |
Re: Anyone help with a plan of attack for body panels
I asked the very same question when I was working on my cab. If you type in "Order of rust repair" in the search bar you see what people told me. (Sorry don't know how to link my thread to your post) Basically I worked from the inside out. IE: Cut out the bad parts of the floor pan and fix those. Then the side kick panel and A-pillar. Then the rockers. Hope this helps.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
01-10-2021, 08:52 PM | #3 |
landarts
For the order in which to do the repairs I would start with pulling off the rockers first to see if anything else reveals. Meaning sometimes when the rocker is pulled off it will reveal that A-Pillar and b-Pillar bottom sections can have rust also. After pulling off the rockers, then remove the portion of the inner rocker that is needed to do that repair. Usually I do the inner rocker-outer floor replacement part install then the rocker. Then move onto the floor parts and the braces. If there are floor sections that are bad under bad braces then I do the braces first the floor section.
Here is a great post on how to replace a rocker by an excellent craftsman. https://67-72chevytrucks.com/vboard/...d.php?t=271066
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
01-10-2021, 09:38 PM | #4 |
Cut off the rockers then the floor patches. Then that way you can tell how much more patching you need on the floor after the inner rocker section is put in. what I use is the inner rocker with the floor panel that goes into the floor a couple three inches and goes from the toe board to back panel You will need to drill out the spot welds on the back panel where the inner goes and add three or so inches on each side for room. I get everything out of the way to fit in the inner rocker screw it down then take either the plasma cutter or die grinder and run right along that edge. If you have a good fit you end up with a nice weldable gap to weld the inner onto the floor also mark out your cab mounts so you can plug weld the mount in. I hope this helps. Good luck and happy welding. Jim
01-10-2021, 10:40 PM | #5 |
You guys are awesome, that's exactly what I needed to know. Thank you.
01-11-2021, 05:04 PM | #6 |
Keep cutting away and post more pics!
My cousin lives in Eagle River. Small world! |
