I've just switched my 6 cylinder to a petronix ignitor system to keep from changing points. I've also added a flamethrower coil. Problem is I'm going thru distributor caps and rotors now. Is there a better brand someone could recommend. I've been using stock parts up until now. I've heard good things about a line classic products has. Any help?
blood type; Retumbo
one word (wel actually 3)
HEI reason, more distance between cyl. towers in cap so you dont end up with burned contacts. not to mention the reliability & simplicity.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Fabricate till you "puke"
Dunno, I am running a pertronix conversion in an old points dist)cast iron, from a 64 chev)+ coil & a good recurve. I like it better than the HEI that i pulled out! I would look for a Bluestreak, Accel, or any others that have brass contacts in the cap. i have heard the stuff about spacing with the bigger caps......but IMO ,its BS. I can twist my 383 as tight as I want with the small cap, & no missfires
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
