Old 01-20-2021, 07:08 AM   #1
kenm78
Broken Down
kenm78's Avatar
84 K10 Wiper Switch
Good morning,
I need to replace my wiper switch in my 84 K10. It has tilt wheel with standard high, low, and mist options. (No intermittent on selector)
When I search for the replacement switch I see the only switch close to my application is a DS397 that says it’s for tilt wheel with pulse wipers.
Is pulse wipers the intermittent feature or is this the switch I need to purchase?
The old wiper motor was slow and wouldn’t spray. I replaced it and now the wiper motor won’t stop spraying and is still slow.
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-21-2021, 02:17 AM   #2
Pontiac1976
Pontiac1976's Avatar
Re: 84 K10 Wiper Switch
yes wiper break down https://bowtieguy.proboards.com/thre...-washer-repair
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
