Old 01-21-2021, 09:29 PM   #1
Dleslie212
A couple of questions
1977 K10 350 with 700R4
I am a few days into installing my new Pro Flo 4 kit and had a few questions that are more specific to square bodies than to the Pro Flo.
First - the kit comes with a replacement distributor that is not HEI. My alternator had a pigtail feeding the old HEI distributor. I should no longer need that pigtail, correct? If so, can I just replace the alternator with a new "one wire" alternator feeding the positive battery terminal?
Second is looking for recommendations for a nice looking fuel pressure regulator mounting bracket, if anybody knows of one
Dleslie212 is offline   Reply With Quote
Old 01-22-2021, 12:39 AM   #2
farmall
farmall's Avatar
Re: A couple of questions
I hope you take a lot of pics because the PF4 would make my K30 so drivable, enjoyable, and reliable. 0 to 6K' can happen any day and -10 cold starts with crisp throttle response would be great.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 01-22-2021, 11:17 AM   #3
SCOTI
SCOTI's Avatar
I can't offer a suggestion on the fuel pressure regulator mount other than use Google to search images & hopefully narrow down what you seek. Then use those images to determine the what/where/who of the part.
I will say the '1-wire' alt can be an issue if you actually drive your vehicle & it fails on the road. Plug & play is better for vehicles that are actually driven as replacement parts are available @ most local places.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
