Old 01-23-2021, 02:04 PM   #1
03BlkZ
Header question
Ok so I am looking at headers for my 70 C10 and have a question. My truck kiss a 3 on the tree with a 350 and I'm wanting to put long tubes on it since I am nearing the end of my restoration. I mainly want them for looks. This will be a cruiser and car show truck. My only problem is the only ones I find that seen to say work with 3 on the tree are ceramic coated. Thats fine but I still need to do my initial engine break in process. Every one says that the break in process will ruin the coating. I found summit has an uncoated set that I like but they are out of stock and estimate 4/22/21 before being available. Am I good to just use the ceramic ones? Here is a pic of the engine. Oh and ignore the wheels . I will be using the 15x8 6 lug Ralley wheels.
03BlkZ is offline   Reply With Quote
Old 01-23-2021, 05:37 PM   #2
SIXTY9
Re: Header question
If you have a old pair of exhaust manifolds rig them up to do the break in and then install your new headers.
SIXTY9 is offline   Reply With Quote
Old 01-23-2021, 07:41 PM   #3
03BlkZ
Re: Header question
That is probably what I will need to do. Just don't want to spend extra money for nothing on the exhaust. I have the old rams horns but I will need gaskets and bolts.
Old 01-23-2021, 09:54 PM   #4
Mike C
Mike C's Avatar
Re: Header question
If you are just breaking it in, buy the cheapest set of headers you can find and some collector mufflers to do that. Then put your coated headers in and hook up all the neccesary clutch linkage when that is finished. You certainly don't want to buy a GOOD set of uncoated headers and then have to get them coated.
Heddman was the only header I could find that really did work with my Jimmy and the SM465.
But the Corvette rams horns are a better solution if you are less than 400 hp...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-23-2021, 09:56 PM   #5
SIXTY9
Re: Header question
Let me check with one of my buddies and see if he has a old set of headers. Probably just postage to get them there.
Old 01-23-2021, 11:03 PM   #6
03BlkZ
Re: Header question
Sounds good
Old 01-24-2021, 04:04 PM   #7
MikeB
MikeB's Avatar
Re: Header question
The Corvette rams horns drop straight down near the crossmember and there's no room to connect head pipes. As I recall, the exceptions are trucks that mount the engine farther back, such as 69-72 4WD trucks and 67-68 2WD and 4WD trucks..
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 01-25-2021, 06:03 PM   #8
SIXTY9
Re: Header question
Sorry no luck on the headers. He got rid of a bunch of stuff and the two sets of headers went too.
Old 01-25-2021, 06:57 PM   #9
BigBird05
Re: Header question
Not trying to hijack the thread but what exhaust manifolds were stock on a 72 C-10? Straight down or angled back.
BigBird05 is offline   Reply With Quote
Old 01-25-2021, 09:20 PM   #10
Tomchev
Re: Header question
They were angle on both sides.
Tomchev is offline   Reply With Quote
Old 01-25-2021, 10:25 PM   #11
Mike C
Mike C's Avatar
Re: Header question
A good exhaust shop can make it happen, but you are right, moving the motor back to the 6 cylinder spot allows for maximum clearance. Also improves the weight balance of the truck. But requires lots of work and a new driveshaft.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 01-26-2021, 10:16 AM   #12
MikeB
MikeB's Avatar
Re: Header question
That's exactly the right description for 69-72 trucks: 6 cyl vs. 8 cyl position.
My 69 has a ton of space between HEI and firewall, but I'd rather it was moved back. However, as you said, it's a lot of work (and parts) just to use 2.5" straight drop rams horns.
I wish the aftermarket would make 2.5" or even 2.25" angled rams horns. The stock replacements are necked down to 1-7/8" or less.
Mike
Old 01-30-2021, 11:11 AM   #13
03BlkZ
Re: Header question
Thanks for all the advise. I decided yesterday that I will reinstall the original manifolds for the initial break in then worry about the headers at a later date.
Old 01-30-2021, 01:27 PM   #14
Grumpy old man
Grumpy old man's Avatar
Re: Header question
The 2 1/2" straight drop rams fit in the stock V8 position in a 2 wheel drive .
Old 01-30-2021, 01:34 PM   #15
MikeB
MikeB's Avatar
Re: Header question
What year is the truck?
Nice looking engine!
Mike
Old 01-30-2021, 01:44 PM   #16
Grumpy old man
Re: Header question
67 , this is the bend required to clear the starter ( and still be easy to drop) the clutch linkage and the cross member , It's a 4" bend .
Old 01-30-2021, 02:41 PM   #17
MikeB
MikeB's Avatar
Re: Header question
Your engine is mounted in the rearward position, right? In 69 they started using the forward mounts for V-8s.
Mike
Old 01-30-2021, 03:00 PM   #18
Grumpy old man
Re: Header question
No , It was originally a l6 frame and I removed the 6 manual trans cross member and replaced it with a stock V8 manual trans cross member to have the engine sit in the stock V8 forward location and run a Muncie M-22 4 speed , You can see it's mounted in the forward position .in 67 they used the front holes to mount a V8
