Can I lower the ECE 4/6 drop kit further?
I have the ECE 4/6 drop kit currently, however, I was wanting to go lower in the front. I was wondering if I could swap out lowering springs to achieve this? It came with 1.5" drop springs, but I saw where Performance Online has drop springs in 2", 3", and 4" drops. If I bought the 4" drop springs that would theoretically get me from a 4" drop in the front to a 6.5" drop in the front. Is it that simple or is there more to it?
Thanks. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Can I lower the ECE 4/6 drop kit further?
Yes, you can replace the current ECE 1.5 springs with something more aggressive. I'd really urge you not to go below a 3 inch spring though. That's 5.5 total drop and that's quite a lot. Beyond that you might look into options like crossmember mods or even a dropmember setup.
x2.
The shorter the coil spring, the less travel there is & the closer the contact points up front come to the road surface. Measure your lower a-arm @ it's current lowest spot. Measure the lower a-arm mounting shaft pivot points. How far is it off the road surface now?
Thanks for the quick reply. I will go for the 3" lowering springs then. I was thinking about a PB dropmember, however, I think the 3" lowering springs will give me a good stance, and will be a lot less work given it the rest of the ECE kit is already installed.
Thanks again. |
#5 | |
Then measure the closer of the sides. That's what you'll be dealing w/when driving (roads are never always flat).
I've always had lowered trucks/cars. They suck to drive when they're lowered in such a way that compromises the 'ability to drive'. Constantly bottoming out. A-arms impacting uneven road surfaces. Tires buzzing the sheet metal. Driving something low but still has clearance should be the goal.
Tags |
4/6, early classic, ece, static drop |
