Old 01-25-2021, 06:14 PM   #1
hodag
Unhappy Gas Line run on a S10 frame with homemade cab brackets. How do you run them?
I built my cab brackets They rest on top of the frame so the stock S10 line can't run on top. What has everyone done to get them up front. Rebend lines around the cab brackets or just run new one all the way from the back to the front? How did and where did you attach them along the frame? I am wondering. Thanks.
Hodag
hodag is offline   Reply With Quote
Old 01-25-2021, 06:41 PM   #2
MiraclePieCo
MiraclePieCo's Avatar
Re: Gas Line run on a S10 frame with homemade cab brackets. How do you run them?
How about drilling holes in your cab mount brackets to run the lines through?
I always run all new lines from back to front. I realize part of the appeal of S10 conversions is that all the brake lines and fuel lines are already installed, but often they're filled with gunk and rust and should be replaced anyway. And it's really a simple process to make new lines.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 01-26-2021, 12:03 AM   #3
dsraven
if unsure what to do, get a double flare tool, practice some with some extra tubing, then cut the offending length of the old lines out, back a bit from the brackets. use a tubing cutter for this, then slip a new flare nut over the tube and do a new double flare on the tubes. then make a connector tube to fit between the cut off parts, formed so that it is bent around the bracket. source some double sided connectors for the flare fittings so you can install the patch tube in between the cut off tubes. bleed the brakes, that will get you going till you decide if you need to change it later.
Old 01-26-2021, 12:30 AM   #4
joedoh
joedoh's Avatar
I doubt the forum picture size will let you see it but I angle the snap retainer and screw it right to the back of the mount.
Old 01-26-2021, 10:17 AM   #5
hodag
Great replies, I should be able to handle that. Thanks!
Hodag
Old 02-06-2021, 02:04 AM   #6
jocww
I ran my fuel lines inside my rails. Its a tci, but Im sure you could prob do the same
My build a 49 5 window ls1 4l60e on a TCI chassis
http://67-72chevytrucks.com/vboard/s...d.php?t=754926
My travel blog
The Wong Winding Road-Adventures of The Chinese Cowboy
https://thewongwindingroad.blogspot.com/
jocww is offline   Reply With Quote
Old 02-12-2021, 01:54 PM   #7
Black93GT
Black93GT's Avatar
I only used the S10 lines as far forward as the fuel filter. For me this was approximately at the back of the seat. The fuel pump is just ahead and draws directly from the filter. The regulator ties into the return line in that same spot. I routed the carb line directly up to the cab floor and to the passenger side before coming forward.
'49 3600 build
SBC 350, a T-5 and some patina
Black93GT is offline   Reply With Quote
gas line placement
