Old 01-26-2021, 11:22 AM   #451
SCOTI
SCOTI's Avatar
Re: SkinnyG's '61 Apache
Originally Posted by SkinnyG View Post
I'm having second thoughts about how I did the end board widths. I cut them so they did not go past the bolts. I think they should go past the bolts to better support the sides.
It looks like I should have cut the end boards at 4".
Which I -had- done, and then second-guessed myself.
Guess I'm ordering another board....
2nd round is always better 90% of the time
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-26-2021, 11:45 AM   #452
SkinnyG
SkinnyG's Avatar
This is 3rd time around.
Just called Home Depot, and GUESS WHAT HAS JUST BEEN DISCONTINUED.
Nice.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-26-2021, 11:54 AM   #453
SCOTI
SCOTI's Avatar
Nice.
So the 3.5's it is. Don't sweat it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2021, 12:01 PM   #454
SkinnyG
SkinnyG's Avatar
How large of a gap between the bed side and the edge of the board is acceptable? I currently have them against the bed side bolt; the bolt does not go through any board.
Old 01-26-2021, 12:09 PM   #455
SCOTI
SCOTI's Avatar
Ahh.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2021, 02:17 PM   #456
SkinnyG
SkinnyG's Avatar
Whew.
A different hardware store in town, that had told me in person back in December that they do not carry composite deck boards, actually carries composite deck boards. And actually had two 20' lengths of Trex Winchester.
When I had asked one dude at the order desk, another piped up that Winchester is discontinued, and they had none. My dude said they list two in the computer. The yard guy couldn't find them, so I went in to get reimbursed, but my order guy took me to the secret stash of composite.
What a schmozzle.
I will post up the confirmed widths for the end boards in a while.
A contributer to this mess is that I did not notice that the angle strips do not fit in grooves on the end boards, but rather fit on top. That is not how I installed the angle strips - I set them to be at the same height as all the rest of the skid strips.
I'll need to adjust how I groove the end boards to fit how I mounted the angle strips.
Issues, issues, issues.
I should probably take up drinking.
Old 01-26-2021, 05:29 PM   #457
SCOTI
SCOTI's Avatar
Whew.
What a schmozzle.
LoL. After the work will be my suggestion.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2021, 07:16 PM   #458
SkinnyG
SkinnyG's Avatar
SCOTI - do the skid strip 1/4" round portions actually touch the bottom of the wood grooves, or do they hover and the flat "bolt" section only touches it's wood groove "step"? Or both?
Old 01-26-2021, 07:40 PM   #459
SCOTI
SCOTI's Avatar
On my old stuff (OE wood) the rounded edge touches. I believe most 'new' pre-cut wood doesn't. I recall Mar-k providing dimensions for those attempting to cut their own that gave a range of depth for the groove depending on how 'high' off the wood you wanted the strips.
Point being... I imagine it depends on the manufacturer, age, &/or personal likes.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-26-2021, 08:27 PM   #460
SkinnyG
SkinnyG's Avatar
Ok. I can roll with that. Thanks!
Old 01-26-2021, 10:05 PM   #461
Low Elco
Just read the whole thing. Fantastic work, please keep it up!
Low Elco is offline   Reply With Quote
Old 01-27-2021, 01:02 AM   #462
SkinnyG
SkinnyG's Avatar
Ok. By my math, it looks like if you're using 5.5" Trex composite boards, you will need SEVEN boards 5-1/2" wide, and TWO boards 4-5/16" wide.
This should work with the 1/2" gap between boards, and 1/16" gap either side of the skid strips.
Film at 11.
I'll confirm when I'm good and ready to run everything through the table saw.... again.
Old 01-27-2021, 10:22 AM   #463
SCOTI
SCOTI's Avatar
Film at 11.
So.... I recall the 1/2" gap between boards is to allow the space for wood expansion w/moisture cycling right? With the Trex, I'm curious if that can be minimized since a composite board shouldn't have such issues?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-27-2021, 10:54 AM   #464
SkinnyG
SkinnyG's Avatar
Mar-K says the 1/16" gap between the wood groove and the skid strip is critical.
Trex instructions still require gaps, at ends and at widths because they still expand.
I cut the boards at 77" length instead of wood's 77-1/8", because the composite will expand in every direction, whereas wood will change less in length and more in width. Some say the composite expands more than wood. Some folks here just cut them up like wood, installed them like wood, and they work fine.
The 1/2" between the boards is really only 1/16" of movement until the grooves hit the skid strips, so you're not talking a lot of width change really. I imagine you could close the gap, but it wouldn't make a difference (other then you'd need another skid strip and another board to fill the collectively reduced gap).
Old 01-27-2021, 10:59 AM   #465
SCOTI
SCOTI's Avatar
Gotcha. I looked into the Trex initially because I wanted something that would not distort like wood can/does w/the moisture cycling issue. Once I found the width/thickness options were limited, I decided to just use wood. My '64 had what appeared to be the original wood still in place. A couple of the short board fore/aft of the wheel tubs & one full length board were split in half; the rest is in decent shape for being >50yrs old.
I figured advanced coating on some new wood should see it through MY expiration date @ this point.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-30-2021, 01:45 AM   #466
SkinnyG
SkinnyG's Avatar
I re-cut two new end boards on the tablesaw today, to the new measurements and grooved to fit. No picture because it doesn't really look any different. Well, the end board look different, but they will look no different once installed.
Still irked that this board is discontinued. At least I have two spare boards I will store somewhere.
Hopefully get back at it Saturday.
Old 01-30-2021, 10:07 PM   #467
SkinnyG
SkinnyG's Avatar
Saturdays are going to be less productive, as the kids have a 3-hour shin-dig smack at mid-day - takes a big chunk out of doing something useful with the day. Not enjoying that, but it's good for the kids.
Much happier with the fitment of the new end boards. No pic, because it looks no different.
Also corrected irregularities in the drip rail edge. Nothing magical there.
Also cut some scrap steel to fab up the panhard rod. I have what will be the tabs at the trailing arm end cut out, but not finished. I'll see how far I get tomorrow.
Old 01-31-2021, 11:48 AM   #468
88Stanger
88Stanger's Avatar
SkinnyG - You are talking about the Trex boards you used in the bed, correct?
i am really seriously looking into this. My only issue is when i was looking at them they show a groove cut into each edge. is this same type of boards you used? I was just wondering in reference to how you cut in the cuts needed for the metal strips that hold down the wood.
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 01-31-2021, 02:00 PM   #469
SkinnyG
SkinnyG's Avatar
Trex comes in grooved and NOT grooved. I bought NOT grooved.
I cut the boards for the skid strips with a table saw, following the dimensions at GMCPauls. It will eat your table saw blade, or you can spend $80 for a Diablo Composite blade.
Old 01-31-2021, 10:06 PM   #470
SkinnyG
SkinnyG's Avatar
Panhard mounts tacked in:
Old 01-31-2021, 10:41 PM   #471
53Sparky
53Sparky's Avatar
nice work. I like the adjustability.
We'll burn that bridge when we get there
My current project: Rust Therapy 62 C10
Numbers 6:24-26
53Sparky is offline   Reply With Quote
Old 01-31-2021, 11:14 PM   #472
SkinnyG
SkinnyG's Avatar
It's not much adjustability - the roll center is largely dictated by where it mounts to the 2" block on the right. I'm reasonably sure this will be ride height, but I might be wrong - so being able to move the panhard according to final ride height is good.
Old 02-02-2021, 10:46 AM   #473
88Stanger
88Stanger's Avatar
Aw.... this is did not know or see. Thanks, and thanks for all the info here.
Old 02-03-2021, 02:16 AM   #474
SkinnyG
SkinnyG's Avatar
Finished the panhard, but I'm not happy with the side-to-side motion of the bar, with the front-to-rear motion of the truck arms. Looks like binding to me. So I'm going to cut it down and go spherical rod ends.
Old 02-08-2021, 01:59 PM   #475
Slammed66
Needs a Big Block
Slammed66's Avatar
SkinnyG
What year / model fuel tank did you order -
I have a 62 suburban that looks to be a good fit
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
