turn signal malfunction
blinkers only work on driver side front. bought a new flasher at the fuse box and same thing. anyone else had this problem before?
*UNDER CONSTRUCTION* '80 Suburban C20 (C6P) (Silverado) - '68 472 (Edelbrock 1813, PH8026 LT's, H pipe) / '91 4L80 (manual shift,vac modulator, 350 converter) / 14B FF 3.21 G80 34' s/ '96 GMT400 interior |
![]() Join Date: Mar 2003
Re: turn signal malfunction
Brake lamps work in the back?? Switch itself? connector loose under dash coming out of the column
brake lamps have not worked since i bought this truck 5 years ago. when trying to to put a new fuse in at the fuse box it instantly pops. I checked the connector under the dash its plugged in nice and snug.
Brake lights use the same filaments as turn signals in the 1157 bulbs. They're also more important than turn signals so that's the place to start. The same flasher is used for both sides so it obviously isn't the flasher.
Time to get out the multimeter, wiring diagram and troubleshoot. |
