![]() Join Date: Jul 2015
Interior Door Lock Handle
Can anyone explain how these doors are supposed to work?
The lever inside the cab has a lock position, neutral position and an open position. If I close the door with the handle in the lock position I cannot unlock it from outside. However, if I close the door in the neutral position, I can open the door or lock it from the outside. Shouldn’t I be able to unlock the door from the outside? My keys are matched on both door locks. Thanks Leon! (Lock Doc) Also, how is the handle supposed to be oriented? Thanks!
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 02-06-2021 at 01:05 AM. |
![]() Join Date: Feb 2020
Re: Interior Door Lock Handle
Dunno. My 64 with the handle in the lock position and the door open will not stay locked when I close the door.
Moderator
![]() Join Date: Dec 2012
Going from memory on my custom comfort-equipped 65:
passenger side handle: down for lock, middle neutral, up to open |
I think you use the key to lock it from the outside.
For orientation, on my 63 C50 the handles on both doors point pretty much straight down in their normal unlocked/unopened resting position. Maybe someone else can chime in but I don’t think the handles have ever been rotated.
Might be so nothing on your person can get caught when in a hurry on the way out the door
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
The lock cylinder on the outside of the truck is independent of the door handle on the inside. So yes, if you lock the truck from the inside with the handle, you're not going to be able to unlock using the key from the outside. As I recall, stock C-10s of this generation shipped from the factory with just a lock cylinder on the drivers side, so the passenger side could only be locked from the inside.
My truck ain't dead, it just smells funny. |
#7 | |
Moderator
Great reading here: http://67-72chevytrucks.com/vboard/s...d.php?t=520298 |
So, if you move the door handle to the lock position and close the door, you cannot unlock it? That is effin ridiculous.
1963 C20, small window, long bed 292, 4-speed |
#9 | |
![]() ![]() ![]() Join Date: Jan 2018
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Moderator
You unlock the driver's door, reach over, and unlock the passenger side. Like others, I just lock/unlock mine from outside. It can be convenient, though, if you think about it. You're in the truck. You park somewhere. You only have to simply reach over, flip the handle down, and the passenger side is locked. No need to walk around and use the key. Not so effin ridiculous, IMO...
I thought the lock in the button was on the passenger door... because everyone exited the vehicle from the passenger door. Just watch an old television series from the 50's or 60's... they all got out on the passenger side.
I get what you guys are saying, but I could see my GF locking herself out, or me. Guess she can’t drive the truck by herself.
Moderator
Only if she locks the keys inside, just like every other vehicle...
#14 | |
#15 |
Mr. Hat, I have a '64 and a '66. I just went out and opened every door and pushed the handles to the lock postion, then shut the doors. ( windows down of course.) On 3 out of the 4 doors the handle snapped back to the unlock position when the latch hit the striker. I can only assume the one that didn't must have a problem of some kind. Edit: also when reaching in thru the window and locking the interior handle on a closed door, I am still able to lock the pushbutton on the exterior handle on every door.
#16 | |
1. What orientation are your door handles? 6 o’clock? 2. Even though you are able to lock the push button on a locked door, it still won’t open when unlocked, will it?
#17 |
I pointed my handles at the two o'clock position because I'm pretty tall and I just wanted the dang thing up and away from my knee. And correct, the door will not open until the interior handle is unlocked. Conversely though, I can reach over and open the passenger door when the button is locked.
Theoretically, a person could double lock the passenger's side door but here's my thinking on that: If I have a passenger, I won't just reach over and pop it open for them and leave the button locked during driving because If I were to crash, I would want any potential rescue party to be able to open the door from the outside. Something about the idea of my wife being trapped unconscious inside while rescuers yank fruitlessly on the door. The only time I would even lock an inside handle is when parked and sitting inside. Last edited by AcampoDave; 02-06-2021 at 11:06 PM. |
#18 |
Moderator
#19 |
I think I get what you guys are saying; so, bottom line, the key won’t make any difference if it was locked from the inside.
