#326 |
Re: Jeep Trailblazer SS
I went grocery shopping before work and when i came home, the rims were outside my garage. I need to get valve stems, but i wanted to test fit them to make sure i did my math correctly. They're just about flush with the fender flares, which is perfect. I'll mount and balance the tires after work.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R |
#327 |
So i got home and mounted and balanced the wheels and put the rear wheels on. I'm still waiting for the adapters for the fronts. I put the new tire under the trailblazer wheels to show the difference. I absolutely love the new look.
-Josh
1967 Buick Special wagon 1968 Jeep Wagoneer 1958 Chevy Panel Truck 2017 Suzuki M109R Last edited by gottattooz; 02-15-2021 at 02:48 PM. |
#328 |
New wheel/tire combo looks great! they really fit the build and I am willing to bet that for those not very familiar with Jeeps will think it is a stock off-the-lot Jeep. Hat's off to you and your dad for a job well done!
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#329 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#330 |
The front adapters came in. I had to trim the lug nuts to keep them from sticking out. I bolted on the tires and took a test drive. It's exactly the look i was going for. The wheels are right to the edge of the flares. I don't know that i could be any happier with the results.
-Josh
#331 |
Jeep looks great. I wanna see pics of the wagon in the garage.....
#332 | |
-Josh
#333 |
![]() Join Date: Nov 2004
Great wheel choice, cool nod to the original turbines these came with (although maybe not as old as this one was? Might be been an 80's grand wagoneer thing)
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#334 |
Who Me?
This is sweet too!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#335 | |
#336 |
![]() ![]() Join Date: Jul 2002
Nice Buick wagon. Those wheels are much better on the Jeep than what was there.
#337 |
![]() Join Date: Nov 2018
Are you gonna show the people or did I just get special privileges?
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#338 | |
I went over to MadKidd's house to show off the Jeep. We played around with putting ls2 decals on. We cut the ls2 part off and put the 6.0l part just under the front corner lights. Since the Ls2 has a knock in the lower end somewhere, my plan is to put a cam in a lq4 6.0 that i have in the garage and swap it out. With lower compression (9.4 vs 10.9) i can run 87 octane and it'll have a nice lopey idle. I've been looking to replace the spare tire since i changed the bolt pattern and tire size. Turns out i had the correct tire size in my shed on a set of 2015 Colorado wheels i bought back in the day for the 68 c10 i had. I swapped the tire onto one of the GMC rims i have and put it in the spare tire carriage underneath. Now that it's more of a driver, i tackled the wiring for the overhead consoles and rear view mirror. It sucked not having dome lights, and the mirror auto dims at night. Even the fold down dvd player for the back seat passengers works! -Josh
#339 |
Nice....looks good!
#340 |
Been following from the start - the new rims look great! So glad you changed them - the original ones just didn't jive w/ the jeep
#341 |
So i ditched the Mercedes wiper. The air dam looked way too goofy. I got another wiper regulator from MadKidd (i cut mine apart trying to adapt the trailblazer motor to the Mercedes transmission). Fortunately. Since the front crossbar bolts into place, i figured out my mounting brackets, clamped them in place and then removed the bar to weld everything together instead of trying to protect the new paint while welding over the roof. I painted everything black and, if you zoom in, you can see the sweep of the arms goes from the edge of the glass down to the bottom of the cowl. I've just got to wire it up and hopefully it'll all be done.
-Josh
#342 | |
#343 |
Another job well done on that wiper setup. It really fits this one-of-a-kind vehicle, almost gives it that Dakkar Rally look. I also have to give another thumbs up on your wheel choice!
#344 |
#345 |
Ii finished routing and wiring the wipers. I bought 25 feet of trailer wiring and ran 2 lengths because there's 8 wires. I ran it through the firewall boot and up the a pillar. I drilled a hole through the base of the roof rack and siliconed the hole. I wrapped everything with electrical tape and secured it to the back of the front railing to the wiper. And everything works. Intermittent, low high and park.
-Josh
#346 |
I swapped out the power window regulator in the tail gate for the manual setup. The gears would jump a tooth every time i tried to roll the glass up, and then it developed a dead short that kept blowing the fuse. Luckily I found the key that fits so i can lock the crank handle.
-Josh
#347 |
Nice Job. I forgot they had the manual cracnks. Been so long since I have seen one.
#348 |
No updates. Just took her out for lunch and got a really good picture with the Jeep.
-Josh
#349 |
![]() ![]() Join Date: May 2015
turned out nice...!!!!
#350 |
Jeep looks good!!!
