#401 |
![]() Join Date: Jul 2018
Re: Volt Gauge Conversion Kits
Checking to see if you have any of the kits available with original face?
1971 Custom/10 - 350/3 speed, Orange/White roof |
#402 |
Cluster King
![]() Join Date: Nov 2012
Good morning,
I am currently getting parts together to make more conversion kits. They sell rather quick when I have them. I will be posting when I have a few kits ready to sell. Thank you all for the interest. Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#403 |
My son has a 69 with gauges already in it. So, as I am kinda dumb on this stuff, is this something where he can use his already existing gauge and just convert it to be useable with a new style alternator? We redid all the wiring with AAW, and the new higher amp alternator is not able to be used on the gauge on the cluster. I hope this makes sense. RR
#404 |
@ Redrocker ;
These REPLACE the original ammeter and give you better information and can be used with any alternator . No down side here as the look original .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#405 |
#406 |
I apologize for being stupid up front, but my son has a 69 and is looking to keep the dash stock looking. What is the cost for your setup with a stock looking gauge? Again, sorry for being slow, but I saw a couple of prices there and want to make sure I understand.
RR |
#407 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I've had one of teses in my truck for 4/5 yeas now and it works great. Did the install myself and yes look like they put in at the factory as you can see in these pictures.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#408 |
![]() Join Date: Aug 2019
Are the new ones ready yet?
#409 |
Cluster King
Not yet but working on parts to build some more kits.
Thank you, Tom
#410 |
RR wrote :
"I apologize for being stupid up front, but my son has a 69 and is looking to keep the dash stock looking. What is the cost for your setup with a stock looking gauge? Again, sorry for being slow, but I saw a couple of prices there and want to make sure I understand. RR " NOT STUPID ! . caring enough to want to do what your son likes is a good thing . The entire point on forums like this is to help others.... I'm an old Journeyman Mechanic who worked on these when new but there's still so much I don't know so I come here first to ask what to do, how and why . Many different ways to skin a cat . When you have some old battered klunker I usually know how to resurrect it and make it run well even when it has low compression etc.
#411 | |
Cluster King
I am waiting on some parts. I have about a dozen people waiting and it seems busier than normal lately. I am generating a list and will gladly put you on it. Thank you. I hope these are not to far out but have limited control. Tom
#412 | |
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#413 |
It’s been months since he’s been on here
#414 |
As stated in Post # 407 I've had one of these in my truck for quite a while now and it functoned as it should. This summer when started using the truck the gauge would show 3/4 of the way across and for the last while pegs right over to the right and soon as you start the truck and stays there as long as truck is running. When the truck is shut off it parks just slightly above the rest stop. I see Tom hasnt posted for about a year now but postng here in case someone else has run into this and maybe has a solution. I have no electrical issues with the truck.
#415 | |
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#416 |
Yes, the engine not running and key out of the ignition when just above the 8.
#417 |
Can you post a picture of what it looks like with Key on Engine off?
#418 |
Sure. With the needle far right key in on position and engine not running. With the needle just below the 8 engine off and key in the accessory position.
#419 |
Looks to me that the needle is put on too far to the clockwise position. When the truck is off the needle should be all the way to the bottom stop to the counter clockwise direction.
#420 |
Okay and agreed but what made it change all of a sudden from working as it should for the last 5 years cause the picture with the Le Carra Steering wheel shows the needle at rest as far left as can go back in 2018 and the lighted dash pic is from 2020 when it still worked as it should. Thanks for for your observations.
#421 |
Mine did the same thing. Not sure why happened. I bench tested it with a battery and it does the same thing. Disconnected it and haven't done anything with it yet.
Thanks Don '57 Chevy Nomad '70 Buick GSX '72 Cheyene (Boys' truck) |
