![]() Join Date: Aug 2019
rims
Does anybody know if the 1999 thru 2006 Chevy 6 bolt rims will fit on a 1970 C-10?
Gone Fishing
Re: rims
The center hub opening is too small from what I have heard. The opening will have to be opened up some.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
![]() Join Date: Jan 2001
Re: rims
If it's a C10 it should have a 5 bolt pattern...
If it's a K10 the bolt pattern on both is 6x5.5, but the center opening is going to be too small, as mentioned. I found a local machine shop that could open up the center hub on some motor home wheels for me... I think it was $45 to $50 per wheel.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#4 | |
Re: rims
Re: rims
In that case, it should fit, with the proper machining. You also need to consider the length of the wheel studs. You may need to swap them out for longer ones if you're using aluminum wheels.
