#26 |
Re: Electric Fan Setup
I had it custom made at Ricks Radiators in Azusa, CA
#27 |
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#28 |
I did the Volvo fan with a gen1 Camaro LS swap radiator. There was nothing easy about this project. It took about 4 attempts to make everything fit. There is no need to get the Volvo relays. You can wire your own with 2 Bosch relays. I bought a 6 relay box for the LS harness, the fan relays go in there. I haven't got the truck running yet, so I can't comment on whether or not it works
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Wiring the fan: ![]()
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
#29 |
Very nice!
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#30 |
good to know bigglass on volvo. hope i have the room when i sit engine in mine.
#31 |
I am curious as to what signals the relays to go high or low speed?
#32 |
The PCM outputs, determined by parameters in the software. The coolant temp sensor is “read” by the computer, software settings can tailor what temps the fans go on and off.
#33 |
are you using a GM ecu or something aftermarket like a Holley HP, etc.
Thanks for the response. |
#34 |
Big Glass, your work bench looks like it might have been a bowling alley at one time?
#35 |
![]() Join Date: Aug 2010
Here's a less expensive option , 2002 Camero rad and cooling fans .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#36 |
Lots of great information guys. I will have many choices when the time comes. I plan on using the fan 1 fan 2 out puts from the ecm to control the fans. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#37 |
Yep!
