02-20-2021, 11:42 AM | #1 |
Light weight vs heavy weight axles.
As I build my Willys I am looking into doing a break upgrade on my D44 TTB. While not entirely needed I feel it would be nice. It needs parts. Why not upgrade while at it.
I have the choice of better calipers or a 8 lug front swap. Which has bigger rotors, and calipers. Which would also require a 8 lug rear axle. My Wagon should weigh 4200 pounds estimated with me + my son in it, some gear, and a full tank of gas. Or enough for a day of trail riding to explore ghost towns. Factory Willys Wagon weight 3200 pounds. I am on a modified F150 TTb 4x4 frame. So well within the confines of a brand F 8.8 rear end. Especially if built up. If I am not doing any rock crawling. Just desert exploring. My Willys stands about 6'2" tall right now, and will finish off about 6'3" to 6'4" if I don't add a roof rack. Which can add to top heaviness on a short wheelbase truck when loaded. I plan to add heavier steel rims to get some weight lower, and set the drive train as low as possible to help too. Rather then tucking it up higher into the body/frame envelope if you will. So is adding an extra 300 pounds of axles getting to overkill status or will it provide a feeling of safety. Since it's extra weight will be lower which would counter act my top heaviness? Or just stick with the 8.8 as it's strong enough for what I will do anyways. |
02-20-2021, 12:43 PM | #2 |
Re: Light weight vs heavy weight axles.
Okay I'm no build expert but it seems like a waste unless you're going to a solid front axle.
I know of a couple one ton ford axles that might be available but they're at the other end of the country, although it might get hauled out to Arizona for parting.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
02-20-2021, 01:20 PM | #3 |
I actually want to keep the TTB as it works very well with my intended situation.
If by some chance I really get into serious off-roading. I would build a frame, and use brand F super duty parts for solid axles. With my limited 4x4 knowledge, and more importantly friends who go alot. My ability to modify can get the best of me fast. I have even just thought about running a 14 bolt with 8 Lug wheels. Till I get around to conversion. Since steel rims are $100 it is not a big deal for a year or two. Just thinking out loud before I start to commit money to the cause here. |
02-20-2021, 02:11 PM | #4 |
If the TTB is already installed, why not just refresh and rock it? I wouldn't spend the time to do the swap to a solid front end just to put more weight underneath. The Broncos successfully used the set up that you have already got for years and were probably more top heavy than you are.
Besides, how many times have we seen a tail dragging F150 loaded well over capacity? From scrap metal collectors with 1000+ pounds WAY over the top of the cab to guys with cab overs getting around just fine. Get it all sorted from a reliability standpoint and use the extra time that you have left over to go have some fun exploring with your son.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
02-20-2021, 02:24 PM | #5 |
The TTB is already installed as I chopped down a F150 4x4 chassis to go under my Willys as it had no frame when I got it.
Your right I will freshen up what I have. Then take a spare 8.8 I own, and build it up later much later to swap in with 9" end hubs or something mostly for the big bearings. Just trying to avoid spending money twice, and I get caught up in the possibilities. |
02-21-2021, 09:05 AM | #6 |
I think 1 ton axles would be overkill for your intended purpose. I would run what you have and save he money for now. IF you manage to break something then you can plan the next phase of your build.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-21-2021, 11:55 AM | #7 |
Yeah, my point was the TTB wasn't worth building up.
02-21-2021, 03:20 PM | #8 |
All about them K’s
Kinda funny, this may be the only thread in the history of the Internet that is talking about keeping the ttb axle I totally understand the thought process though and i agree it’s probably the best course of action for now. Got any pictures of your build? I love the old willys.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
02-21-2021, 08:28 PM | #9 | |
Since I only plan to explore ghost towns or mountain roads. It offers everything I need, and good performance on dirt roads. I am not into rock crawling at this point so straight axles are not needed. If into get into crawling I would build a beater, and not use a Wagon. I have posted a few links to pics in other threads. I will do a bit of a build thread when I am done, and I get my computer back. Right now I am fixing the rust, and cut out floors. Tuesday I will mount the motor, and transmission. |
02-22-2021, 03:09 PM | #10 |
Nothing against the TTB for what you are doing. I just don't see why the factory brakes aren't adequate?
02-22-2021, 04:25 PM | #11 | |
It was a lesson I learned, and always go back to when doing brakes. Since the wheel, and tire package I plan to run will weigh roughly 100 pounds a corner. The rims weigh 40 pounds, and 55 for the tire. Where the factory F150 wheel tire package weighs roughly 65 pounds a corner. I weighed them on a scale, and that's what I remember it being. And while I would not use the Willys to tow a car trailer. I am thinking that I could turn my large weather guard cross bed tool box into a trailer for camping gear. I recently saw a new Jeep doing something similar, and it sounds like a neat idea. Plus people in california typically drive like ted kennedy 5 minutes before the bar closes. So I just want to be safe. |
02-22-2021, 10:09 PM | #12 |
Well, I have certainly pushed half ton brakes a smidgen. Like probably close to 20K gross, in the mountains. Rental equipment trailer that the electric brakes didn't work. Not recommended.
I was just thinking, how hard is it to stop driving around jeep trails at 15 mph?
02-22-2021, 10:53 PM | #13 | |
02-23-2021, 03:32 AM | #14 | |
It won't keep people from driving like jack wagons around you but it will at least put you on par (braking wise) with the wagons that they are driving..
02-23-2021, 08:04 AM | #15 | ||
02-23-2021, 12:02 PM | #16 |
I wouldn't upgrade my brakes because of other peoples driving. That's why I buy insurance.
02-23-2021, 02:22 PM | #17 |
02-23-2021, 02:24 PM | #18 |
02-23-2021, 02:29 PM | #19 | |
Right now I have working parking brakes with my drums. Plus they are 11x 2.5 inch variety so they will work pretty good. |
02-23-2021, 07:56 PM | #20 |
Sorry, I thought you were going to tow it up to the mountains? That's what I remember: you were asking about a tow bar versus a trailer.
I can't keep up
