09-26-2019, 12:01 PM | #276 |
Re: Project Screamer - '72 GMC K2500 + DD 4-53T
Very nice and clean. Did you paint it all together or apart?
Ps: I think your fan belt is a bit loose.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
09-26-2019, 04:40 PM | #277 | |
I left the belt loose because I can’t set the vertical height of the fan until I have the engine in the truck and the fan shroud installed. |
10-19-2019, 03:12 PM | #278 |
Painted!
The old Jimmy is painted. I drove down to Denver yesterday and picked him up. The paint job is GORGEOUS! I don't think he looked this good when new. I had the bottom of the cab coated with Lizard Skin to help mitigate the noise from the engine and transmission. I used Lizard Skin on the bottom of my UNIMOG cab. It made a big difference. He's going to sit on the trailer for a while. I'm still working on the chassis and drive train. |
10-19-2019, 04:27 PM | #279 |
Any chance you're going to make a custom SPID sticker for the truck? Make up your own RPO codes for the detroit and other custom bits? It'd be interesting to see GM truck aficionados try to make sense of that one!
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
10-20-2019, 01:53 PM | #280 |
I have considered making my own SPID sticker. I have the correct option code for the 4-53T from the 1979 C-70 that I pulled it from. I’ll have to create my own code for the Fuller transmission since it wasn’t offered. I won’t do anything until the truck is back on the road.
10-20-2019, 06:27 PM | #281 |
Man that looks awesome Burn. I can't wait to see it together.
NHRA Super Street 469C It only runs 10.90 at 156 mph |
10-30-2019, 01:45 AM | #282 | |
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
11-03-2019, 08:29 PM | #283 |
The engine has landed!
I finished the brake and fuel tubing and dropped the engine into position in the chassis. It sure looks good. |
11-04-2019, 07:32 AM | #284 |
Yes it sure does.
03-13-2020, 09:24 AM | #285 |
Any updates?
04-23-2020, 11:43 PM | #286 |
6>8 Plugless........
Man the body looks beautiful!!! When you get to the spid, member chipflyer makes them and he will custom make you one as well. The engine and chassis look sweet too!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-04-2020, 05:50 PM | #287 |
Updates? Hope things are good.
02-23-2021, 05:17 PM | #288 |
Any updates? I've been pretty excited about this build, and want to see it continue.
