Old 03-01-2021, 04:26 PM   #1
Asshat
Asshat's Avatar
Fitment question - C10 rotors on a C20 front end
I have a complete cross smember from a 74 C20, and I was wondering if there is any way to install the 5 or 6 lug C10 rotors on the C20 front end?
The only reason I would want to do this, is if I were to install a 3:08 rear end on my 63 C20. Pretty sure there are no C20 rear ends that are geared that high, so, if I wanted to do this it would require a rear end from a C10 or other vehicle.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 03-01-2021, 08:17 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Fitment question - C10 rotors on a C20 front end
At that point, you're probably better off going with a c10 front cross member. I don't know of a way to put the c10 rotors on the c20 spindles
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-01-2021, 09:04 PM   #3
Asshat
Asshat's Avatar
Well, I don't think I will come across a deal on a C10 front end like I did with the one I got. Was just hoping that IF I did go with a 5-lug rear end, I could change the front easily.
Oh well... I guess I will stay with 8 lugs. Now I will need to find a T5 trans!
292, 4-speed
Old 03-01-2021, 10:59 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
A 73-87 c10 complete front crossmember should be found for $50 without much effort.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-01-2021, 11:12 PM   #5
Asshat
Asshat's Avatar
Not in California! Anything out here that is related to classic cars or trucks is always over-priced, especially by private parties.
I would love to find one for $50!
292, 4-speed
Old 03-02-2021, 10:33 AM   #6
SCOTI
SCOTI's Avatar
The x-members are interchangeable. The difference is in the arms & supporting pieces that attach. The upper a-arm shaft will require the correct shaft for the x-member (for the correct sizing).
I have a 1/2 ton x-member under my R30 dually. I simply used the C30 bracing & the C30 dually arms + steering parts.
But.... The tire size makes a difference on final drive rpms. What size tires? 3.54 gearing might be possible on the HD 8-lug stuff & would be close to the desired 3.08 (which I feel would not be a good choice for a heavy truck).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-02-2021, 11:50 AM   #7
kwmech
Upper arms are the same it is the ball joint that is different. The upper bj bolts in. Lower arm is different b'cuz of the hole for the 3/4t Ball Joint that presses in. And of course the spindle itself is different due to the wheel bearing size.
Old 03-02-2021, 11:56 AM   #8
kwmech
OR it is all being scooped up and sold for scrap due to the 'environmental nazis' making the wrecking yards be as clean as hospitals. Everything has to under a roof and everything in the yard concreted. When the steel prices were up about 8-10 years ago there was an unprecedented amount of yard clean up. Everything was crushed and sent to china--didn't matter what it was. It was an opportunity to clean the yard AND clean up money wise at the same time----A LOT of good stuff was eliminated forever
