Old 03-07-2021, 07:02 PM   #1
Louisvillekytruck
Frame paint or powder coat
What r u guys doing on the frame paint or powder coat and if paint what paint would like to see pics of what u did
Louisvillekytruck is offline   Reply With Quote
Old 03-07-2021, 07:21 PM   #2
C101972
Re: Frame paint or powder coat
I am in the same boat, sandblast frame, ppg epoxy primer, and finish it off with ppg single stage delfleet.
C101972 is offline   Reply With Quote
Old 03-07-2021, 07:26 PM   #3
C101972
Posted via Mobile Device. Frame primed.
Old 03-07-2021, 08:20 PM   #4
zicc1835
zicc1835's Avatar
I painted mine with Eastwoods Chassis satin
zicc1835 is offline   Reply With Quote
Old 03-07-2021, 08:29 PM   #5
Davidf
Depends on “show quality” or ? For vehicles I restore and want to enjoy, I media blast, epoxy prime, then paint With Rustoleum Satin/Semi-gloss (same thing). Rustoleum holds up fine on frames since it never sees sunlight and only the occasional fuel.
Davidf is offline   Reply With Quote
Old 03-07-2021, 09:19 PM   #6
Louisvillekytruck
What about a 100 percent stock show truck.
Old 03-07-2021, 09:22 PM   #7
Louisvillekytruck
How much of Eastwood satin black did it take to do frame what else do u need to do after sand blast how much did u spend painting the frame
Old 03-07-2021, 11:04 PM   #8
burb71
Active Member
In my opinion a good quilty coating of paint gives better protection than power coating, I think power coating is more or porous or has larger microscopic pores.
burb71 is offline   Reply With Quote
Old 03-07-2021, 11:58 PM   #9
davischevy
davischevy's Avatar
I powdercoated the last frame but I will probably never do another one.
I have been using epoxy primer and finishing with Rustoleum 7777 satin black for over thirty years. It works well, looks good and I can touch up with a spray bomb of the same product.
I have a truck that I finished over thirty years ago and it still looks good.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-08-2021, 12:07 AM   #10
Louisvillekytruck
Where do u buy it at how much does it take to do a k20 frame and how much Is it what all do u need to do after sand blast
Old 03-08-2021, 02:22 AM   #11
Accelo
Accelo's Avatar
For me it would depend on cost. Powder coating would be my preferred coating.
Costs seems to vary widely.
I had quotes for $400 to $700 just for the frame, no front cross member included. Added another $150 for the cross member. This price included blasting.
Note; The cross member had to be baked at 900 deg first to remove the grease, that added to the cost.
By the time you add blasting and painting supplies the dollar cost for powder coasting seems competitive to me.
Accelo is offline   Reply With Quote
Old 03-08-2021, 09:17 AM   #12
Peanut74
Well for me powder coating was just to costly so I painted my frame. The steps I did was:
Step 1: Media blasting the frame and suspension: $400
Step 2: Paint parts with POR15: $53
Step 3: Paint frame/suspension w/ single stage: $130
Total: $583
I painted over the POR15 because it is not UV resistant and it was paintable. Hope my info helps.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 03-08-2021, 09:40 AM   #13
May70
May70's Avatar
My buddy is restoring an old Toyota and he had the frame powder coated by the main place in my area that does it.
I wasn't impressed at all with the quality. It seems very brittle and doesn't have much flex. Once it gets a rock chip it will just start flaking off I guess. There was a spot where a pinecone fell on it from a tree and I just took my finger and could keep flaking more and more off. Rust through in various spots.
Ive read you cant really paint over the chipped spots or repair the areas that do start to flake.
Its a no from me.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 03-08-2021, 09:56 AM   #14
Davidf
If you want a stock appearance, Rustoleum will get you close. Or, I suppose Eastwoods Chassis black (never seen or used it). Rustoleum will not flake or peel on a properly prepped part.
Old 03-08-2021, 09:57 AM   #15
Accelo
Accelo's Avatar
May70
The frame powder coat job has something wrong with it.
The reason it it typically used is it is so much tougher than paint.
Especially durable on the underside of fenders and the like.
I could hit my frame with a hammer and it would only slightly mar the finish.
Even blasting it off it tough as the plastic has some rebound to it.
Not at all typical of a good powder coating job.
Peanut74
You did it right. Transporting a frame is no small item to deal with. If one doesn't have a trailer doing the refinishing at home is the only option.
Rick
Old 03-08-2021, 03:51 PM   #16
davischevy
davischevy's Avatar
I paid about $1,200 for all the chassis related parts except springs and axles.
They PC'd the frame, two spare carriers, four inner fenders, core support and all the small brackets, etc.
They did a very nice job, but if you tighten a bolt too much the PC chips and it is almost impossible to touch up. With paint you can touch up in minutes.
To paint after sandblasting, I sand the frame with 300 grit, and coat with epoxy primer, then apply a couple of coats of Rustoleum 7777 satin black. I have the local True Value Hardware order the Rustoleum. I also keep a spray bomb or two of the 7777 for touchup.
I have a truck I did thirty years ago with epoxy and paint and it still looks good.
other Larry
Old 03-08-2021, 03:53 PM   #17
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I powder coated with red then a gloss clear. It has held up very well and is super resistant to chips and scratches. It does not like carb cleaner at all. Make sure you have everything done the way you like it before powder.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 03-08-2021, 04:02 PM   #18
Louisvillekytruck
Sounds like paint is the way to go I will look into rustoleum 7777 satin black does that use a hardener and reducer
Old 03-08-2021, 04:03 PM   #19
Louisvillekytruck
Beautiful red frame
Old 03-08-2021, 04:48 PM   #20
MDPotter
MDPotter's Avatar
I had mine sandblasted and then painted with Chassis Saver in satin black. Sandblasting is the preferred prep for that coating and it is very sticky stuff and has held up well to all kinds of chemicals and can be touched up with a brush. It's a 1-component product so it doesn't dry quite as fast as 2-part products, but it's pretty easy to apply and sticks to rust as well.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 03-08-2021, 04:53 PM   #21
Louisvillekytruck
Anybody used Eastwood satin chassis black
Old 03-08-2021, 07:54 PM   #22
bigmac73
bigmac73's Avatar
the POR15 will not hold up against fluid leaks(brake or Power steering fluid and) it flakes off around the headers on the frame area.
I power wash mine, then hit it with a wire wheel , then OSPHO and soak for 24 hours then power wash again then use the brush on rustoleum rusty metal primer and then coat it with the rustoleum professional black . no issues. takes a few days for the paint to dry and harden
no one is really going to see the frame and why spend a lot of money on it . other than rust protection.
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 03-09-2021, 08:11 AM   #23
Happy_dan
Happy_dan's Avatar
Not on my truck but on a car I did, I sandblasted the whole subframe, then cleaned it good, then epoxy primer, then eastwood two part chasis black. Came out great and easy to touch up if necessary.
Happy_dan is offline   Reply With Quote
Old 03-09-2021, 09:13 AM   #24
Peanut74
2x Accelo
The frame was either not sandblasted good or not cleaned properly.
Old 03-09-2021, 10:32 AM   #25
Davidf
No. But, if you buy the paint in a quart size can, and plan to spray it, it can be thinned up to 20% with Acetone (read the label to be sure). I usually thin a bit more than recommended so it sprays out better. Using the paint from the can, thinning and spraying seems to setup/dry faster than the spray bomb paint. But, clean-up is more of a pain as acetone does not seem to dissolve/wash away the stuff as readily as automotive primer or paint.
Now, if you research Rustoleum on the internet, there are guys that add hardener/catalyst to the paint. Of course, the purpose would be to make the paint more fuel/solvent resistant. But, the downside is it adds a bit of gloss. Not sure what the mix ratio would be, but I would probably try 8:1 and see what happens. Or, try paint, reducer, hardener similar to single stage urethane...8:2:1
