Old 03-12-2021, 09:39 PM   #1
variationperson
variationperson's Avatar
motor won't crank over now
I was working on my cousin 72 chevy truck ,at first it wasn't getting gas from the tank,so I pulled the gasoline off going to the tank and put a gas can to get gas,then the motor stopped cranking over.I ran news wires just like the digram that was showed on here .purple went to the starter,light purple/orange change to the yellow wire,so yellow went to dist,and the other yellow went to the other side of the starter. I put a new ignition switch in it but i am not getting any power to the purple wire going to the starter .could it be the fuse panel ? lmk thanks
variationperson is offline   Reply With Quote
Old 03-12-2021, 09:46 PM   #2
tdangle
tdangle's Avatar
Re: motor won't crank over now
check the neutral safety switch. If an auto trans, it is in park or neutral? Don't laugh, I've done it.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 03-12-2021, 10:38 PM   #3
variationperson
well u might be right because it has a 4 speed in it now but the old links is still in there ,dammit
TY
Old 03-13-2021, 12:08 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
The ignition switch gets its power from the fuse block. I bet you’ve got a dirty or corroded contact in there. I dealt with this on my truck. I don’t remember the specifics but I lost my ignition switch, backup lights and a few others. My K20 is a 4 speed and doesn’t have a neutral safety switch.
Tyler
Old 03-13-2021, 11:11 PM   #5
variationperson
Thank you for ur help ,I put it back in park because a dumbass ran the wire through the links so when i pulled it out of park it stop cranking over .
