Old 03-13-2021, 01:01 AM   #1
aotte1
1953 Modified
A few photos of 1953 modifications, rear frame section being made. Designed to slide into front frame.
aotte1 is offline   Reply With Quote
Old 03-13-2021, 11:04 PM   #2
mr48chev
mr48chev's Avatar
Re: 1953 Modified
That is a beast that will handle anything you throw at it.
My ongoing truck projects:
Old 04-01-2021, 08:22 PM   #3
aotte1
Re: 1953 Modified
Mr. 48 Chevy,
Thanks for support,
Les
Old 04-01-2021, 08:28 PM   #4
aotte1
Re: 1953 Modified
A few more photos, completing rear.
Old 04-02-2021, 06:39 PM   #5
dsraven
Re: 1953 Modified
nice to see adjustments built in on the upper 4 link arms so you can adjust frame loading under accelleration if required. have you done a full suspension travel check to ensure the max height falls outside the "hit the box floor" parameters? looks beefy, what kinda power are you planning?
Old 04-02-2021, 06:59 PM   #6
mr48chev
mr48chev's Avatar
Re: 1953 Modified
That just keeps getting better all the time and may raise the bar a notch or so.
Old 04-11-2021, 11:37 PM   #7
Kermitt47
Kermitt47's Avatar
Re: 1953 Modified
Nice fabrication work. Is your top triangle bar mount attached to the center section or just to the brackets welded to the axle tubes? Offset 8.8 axles are a challenge to get everything mounted. Good to see the built in adjustments.
Kermitt's 47 truck build
Kermitt47 is offline   Reply With Quote
