03-13-2021, 08:57 PM | #1 |
C4 Suspension ?
Hey Guys,
Anyone out there using a C4 front suspension using Flat Out Kit, I am trying to hook up my steering to the column and am finding my Rack conection Double D is not 3/4" ? What source did you use in hooking up the universal joint and what size is this? 17mm ? Hope this makes seance? and any Pics? Thank you for your time, Allen |
03-14-2021, 07:32 PM | #2 |
Re: C4 Suspension ?
Thumb through here and I'll bet you can probably find something that will work for you.
https://www.borgeson.com/xcart/home.php?cat=2&page=1 |
03-14-2021, 08:01 PM | #3 |
Re: C4 Suspension ?
Thank you Sir,
I was acutually looking threw there site when you posted! I think i am limited to a 17mm x3/4" vibration reducer with the C4 corvette's shaft coming out of the Rack that i have ? Thank you again! Allen |
03-14-2021, 09:32 PM | #4 |
Re: C4 Suspension ?
I bought mine from Summit. C4 rack is 17mm DD. Summit has several options for 17mm DD to 3/4" DD universals.
03-15-2021, 10:54 PM | #5 |
Re: C4 Suspension ?
I got mine from summit as well 17mm - 3/4dd. I have some pics towards the end of my build thread
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90 http://67-72chevytrucks.com/vboard/s...d.php?t=746958 |
04-12-2021, 12:05 AM | #6 |
Re: C4 Suspension ?
I used the shaft from the C4 and ground a DD on the end to the steering shaft
You have choices on the coupler DD to size of your steering shaft
04-13-2021, 11:55 AM | #7 |
Re: C4 Suspension ?
be careful with the vibe reducers if you run any angle, they don't usually like too much off angle stuff and will come apart. they are more or less made to run straightline.
