Big Block Transmission
I'm running a BBC 454 with a TH400 transmission with the original rear end and 295/50R15 tires. It runs and drives great but it revs pretty high at 60 mph. I believe the factory gears are 3.73. I want to install an overdrive transmission but I've read that a 700R4 won't hold up to a slightly built 454. So I've looked into a 4L80E which would work great but then comes the issue of not having a controller. They want huge money for a stand alone or you can build some kind of homemade one. Anyone have any experience with this?
Thanks Thanks |
![]() Join Date: Aug 2004
Re: Big Block Transmission
Find a 4l80, not the electronic, that will live a lot longer behind your BB than the 700 will
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Moderator
![]() Join Date: Dec 2012
All 4L80s are electronic. You can get a stand alone controller out of a van, some had separate PCM and trans controllers.
60-66 Nut
I would suggest the 4L80E. Yes the controller and a TPS add up to some money. But you could get away with running a good used 4L80E versus spending $$$$$ having a 700R4 built to hopefully hold up behind a big block. The other issue with an electronic trans is the speedo is electric also. There is no speedo cable connection. There is info online on how to wire a factory ECM to operate an electronic trans as a standalone. That could be an option if you have more time than money
Its pricy but there is the Gear Vendors route.
My 1966 Chevrolet C10 Pickup |
Another alternative is to change the gearing in the rear and run taller tires. This will kill RPM but also probably reduce acceleration some. When I have looked at a 4L80, it was almost a wash with buying a Gearvendors.
#7 | |
Posted via Mobile Device |
You can run the ecm the 4l80e came with
Sloppy mechanic lays out how to do this https://sites.google.com/site/sloppy...ans-controller |
![]() Join Date: Apr 2009
Find Early Diesel Step Van And get Harness And Ecm works perfect
1963 Impala 2021 Harley Road Glide 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2006 Silverado 1500 Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
A CableX box works to change speedo from electric to cable
It's Better With Nitro
I run a US Shift TCM with my 4L80E. I think the Quick 2 unit and harness (TPS) are around $600.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
| Bookmarks |
| Tags |
| 700r4 |
| Thread Tools | |
| Display Modes | |
