Old 03-27-2021, 07:30 PM   #1
murguia
Easiest way to level out my 1968 custom camper 3/4
Picked up a beautiful and practically rust free 1968 custom camper 3/4 ton. I’m the second owner on this original patina truck. 396 with 80k original miles, ps, pb, ac that still works...
It is all stock and the rear sits about 2” higher than the front. I want to level it out, whether that is bring the back down an inch or the front up one inch
What’s the easiest way to do this? It’s springs all around.
Also, what’s the largest size tire I can fit on here? If anyone has some relatively stock 3/4 tons with leveling to 1” lift, pictures would be great
I want to drive this thing daily but I want it level with some beefier tires
Nick
murguia is offline   Reply With Quote
Old 03-27-2021, 08:09 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Easiest way to level out my 1968 custom camper 3/4
Drop spacers/ blocks . Going with 1 drop springs may not give you any drop since the old ones have probably dropped at least an inch
Thats a nice looking truck
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-27-2021, 09:38 PM   #3
Mike C
Mike C's Avatar
That's a great truck. 265 75 16 is an excellent tire size for a C20. I also would go with a 1" block in the back if it's a coil spring truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-28-2021, 01:13 AM   #4
murguia
Right on, I appreciate the info! I’ll look into some one inch blocks for the rear.
Old 03-28-2021, 01:32 AM   #5
lil hoodlum
lil hoodlum's Avatar
It is all stock and the rear sits about 1” higher than the front. I want to level it out, whether that is bring the back down an inch or the front up one inch
Nick
Looks to be a custom camper to boot. I would recomend new coil springs in the front. I just ordered some new front coil springs and optional rear leaf springs for my 1968 C20 custom camper from Eaton Detroit Spring.
https://www.eatondetroitspring.com/findmyvehicle/
lil hoodlum is offline   Reply With Quote
Old 03-28-2021, 02:22 AM   #6
Richard
Looks to be a trailing arm truck. Agree 1" block in back will be easiest route.
Richard
Old 03-28-2021, 08:47 AM   #7
toms68cst
toms68cst's Avatar
Nice truck! Looks a lot like mine.
I wouldn't have even noticed that it's a little bit higher in the back. Pretty common stance for a stock C20.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 03-28-2021, 09:19 AM   #8
leddzepp
Moderator
leddzepp's Avatar
I too leveled my 68 with rear blocks, easy peasy.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-28-2021, 02:03 PM   #9
murguia
Right on! Thanks everyone. I’ve always owned original short beds, but I’m slowly converting to long beds these days. The extra bed space makes a huge difference
Old 03-28-2021, 02:06 PM   #10
67 chevelle
67 chevelle's Avatar
Nice truck
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-28-2021, 04:27 PM   #11
jocko
jocko's Avatar
Rather than "what is easiest" - I'd ask what look you prefer - a C20 that is lowered with a block in the rear to make it level -or- a C20 that is raised in the front to make it level? Quite different looks, depends on which you prefer. A raked look for a C20 is normal. Is this because it just doesn't look right to you, a personal preference for level, etc? I understand - while I don't mind this look on a C20 at all, I can't stand the low-in-the-front 1/2 4x4 look on GM trucks in the 2000's and newer, have always leveled mine out (just seems right for a 4x4 to me, so I completely understand if you just want to level for personal preference). Having said all that - Love(!) your truck, very nice find, congrats!
Old 03-28-2021, 04:57 PM   #12
NorCalC20LWB
Second the 265/75/16 tire size, fills out the wheel wells nicely. As far as lower the back or raise the front, I had my rear leafs re-arched (arced?) to get rid of the raked look. So, stock height front, lower rear.
NorCalC20LWB is offline   Reply With Quote
Old 03-28-2021, 06:38 PM   #13
k29349
Maybe I,m old school, but a leveled truck looks like the ass is sagging unless the whole truck has been lowered and you are going for the lowered look. A leveled 4X4 looks even worse. It,s almost as bad as the Carolina Squat. I like the look of a lowered 2 wheel drive. I still like a very slight rake. Truck in the pic above looks good to me.
k29349 is offline   Reply With Quote
Old 03-28-2021, 07:33 PM   #14
murguia
It’s just a personal preference to level it out back, or have it sit slightly higher than the front. I’ve never lifted a truck, but I’m really coming to love original lifted trucks that aren’t too high.
I just purchased a rear 1.75” lowering block. I’m hoping this does the trick.
Old 03-29-2021, 01:26 PM   #15
Big Kev-O
Big Kev-O's Avatar
The factory rake forces you to lean forward in the seat which can be very uncomfortable on long rides. Not a fan of the stink bug look either. Dropping the rear is simple compared to lifting the front. I tried to find some taller front springs but all of the ones I found had a higher spring rate and these trucks are already stiff. There are 1" spacers you can install under the front spring but it raises the truck 2-3" which would probably effect suspension & steering geometry and require a upper ball joint spacer. Rear spacer is the way to go for the trailing arm guys.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 03-30-2021, 03:25 PM   #16
murguia
Beautiful truck. That's exactly how I'd like mine to sit
Old 03-31-2021, 08:26 AM   #17
northerngmc
northerngmc's Avatar
I dropped my 68 C20 2" in the front and 4" in the rear to level and lower it. You could just use 2" lower coils in the rear to achieve level.
I am running 18" x 9" wheels with 265/65R18 tires. They fill the wheel wells up nicely.
Also a 396 A/C PS PB custom camper truck. Drives great!
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 04-11-2021, 01:05 PM   #18
duke10
Active Member
duke10's Avatar
I have a 72 GMC custom camper and also want to lower the rear. My truck has the rear leaf springs on top of the axle. Is there an easy cost effective way to lower the truck and level it?
Thank you
duke10 is offline   Reply With Quote
Old 04-11-2021, 01:07 PM   #19
duke10
Active Member
duke10's Avatar
I really like the way Norcals green truck sits
Old 04-12-2021, 10:46 AM   #20
NorCalC20LWB
Thanks Duke, like I mentioned above I had the rear leafs re-arced or arched, whatever you call it. I know the cheaper way to lower the rear is to take out some leaf springs, but that seems to have mixed reviews. Other more knowledgeable folks can comment on whether that's a good idea or not.
Thanks for the compliment...
Brian
Old 04-12-2021, 11:01 AM   #21
duke10
Active Member
duke10's Avatar
So your truck also has the leaf springs on top of the axle?
Old 04-12-2021, 11:40 AM   #22
72c20customcamper
All leaf trucks the leafs are on top of the axle . If you do a flip kit the axle is on top and should if not must have a c notch in the frame .I think you end up with a 6inch drop. Seen people put 4x4 shackles to bring it back up .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-12-2021, 11:41 AM   #23
NorCalC20LWB
Yes, started life as a Custom Camper, so a pretty hefty spring pack on top of the axle.
Old 04-12-2021, 02:47 PM   #24
bnorth
Thank you
With a rear leaf setup you can get a drop shackle which is a cost effective way to lower. They usually have a few different holes in them to fine tune how much you want to lower it. They maintain the carrying capacity as well since you aren't changing the leaf spring.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 04-13-2021, 12:21 AM   #25
duke10
Active Member
duke10's Avatar
Thank you Bnorth
