Old 07-12-2004, 10:08 PM   #1
BranZ
Lowering 88 3/4 ton Suburban
I am debating to lower my 88 suburban, which will be 3/4 ton. I want to be able to tow my camaro with it. I just want to add some attitude to the vehicle. I am not opposed to airbags, but I would like to do it with springs. Just a little bit lower for attitude. Any ideas? BranZ
BranZ is offline   Reply With Quote
Old 07-13-2004, 10:12 PM   #2
special70gmc
special70gmc's Avatar
you could do a flip in the back or a lowered shackle and either a drop spindle or drop springs in the front,depending on how low you need to go you can do both -kyle
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 07-14-2004, 08:51 AM   #3
BranZ
Would this hurt the towing capabilities of the vehicle? I do not want to make the vehicle worthless for towing. Thanks, BranZ
Old 07-14-2004, 11:45 AM   #4
crews
It just doesn't matter
Burbs present a little more of a challenge when lowering than a regular truck, but you should be able to get away with a spindle / spring set up in the front ( 3-4" drop depending on taste ) and a shackle kitr in the rear. ( this would be between 2-4" of drop )
I wouldn't personally recommend doing a flip kit if you are planning on towing alot, so you can still maintain proper clearance between the frame and rear end housing.
I ran a Crew Cab dually lowered 4/ 4 with the above shackles and it would tow anything. Plus it had a nice rake too.
Hope this helps.
05 Chevy Silverado..... A rogue BMW guy....
If you don't like me- TAKE A NUMBER; There are people ahead of you!!
crews is offline   Reply With Quote
Old 07-14-2004, 06:12 PM   #5
BranZ
Do you got any pictures of the dually? I would like to see what that looks like. BranZ
Old 07-15-2004, 01:19 PM   #6
Grim Reaper
Rear: pull a couple leafs or drop shackles then get a set of help bags. When you towing you can air it up to get your capaicty back. Front I would do spindles if you can find them for a 3/4 ton.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
