Old 04-03-2021, 06:36 PM   #1501
Gregski
Gregski's Avatar
Re: A '54 named Busty
so the rear speed bleeders aka speed thread leakers did not work for us, we got more bypass action than through the hole, and we even tried the just barely crack it open trick rather than the 1/4 turn twist to get them to bleed, so we went back with the stock bleeders in the rear, the front ones worked, so we kept them, I don't like returning parts but for $30 bucks these will be going back, just wanted to share
and a huge thanks to Pontiac Mike who swunged by for the first time in over a year to help a brother out, (we know he really wanted to get out of baby sitting his grandaughter, but shhhh I won't tell)
Gregski is offline   Reply With Quote
Old 04-03-2021, 11:44 PM   #1502
Gregski
Gregski's Avatar
so the next hurdle to get over is to fab a custom lower bracket for the steering column since the aftermarket one I bought is a joke and an insult to Hot Rodding, I would not install this on my kids Big Wheel it's that flimzy and it doesn't even fit around the steering shaft
Old 04-04-2021, 08:42 PM   #1503
Gregski
Gregski's Avatar
I've been meaning to fabricate this rear bumperette to go behind the rollpan for quite some time now, and what better time than Easter Sunday
Old 04-04-2021, 08:43 PM   #1504
Gregski
Gregski's Avatar
I am most proud of using all Corono Virus scrap metal
Old 04-04-2021, 08:47 PM   #1505
Gregski
Gregski's Avatar
of course I had to run to Depot Home twice to get some MIG wire for the spark machine, the first time they put flux core wire in the MIG wire bin, and I didn't bother checking, the second time they were all out of .030 wire until I looked in the .025 bin and found two spools, next time I'm going to LOWE's
note the single bolt hole per side to reduce weight (ok so I was too lazy to drill two holes per side)
Old 04-04-2021, 08:49 PM   #1506
Gregski
Gregski's Avatar
I think I even managed to spritz some gray primer on the metal to prep it for bondo and sanding before the final two stage powder coating tomorrow, ha ha yeah right
Old 04-05-2021, 10:43 PM   #1507
Gregski
Gregski's Avatar
made a lower steering column bracket for my late 50s truck / impala steering column
started out by carefully selecting the very first pipe I saw
than we lopped 4" off of it and split it in half... half moons style
Old 04-05-2021, 10:49 PM   #1508
Gregski
Gregski's Avatar
then we made fools out of ourselves by tryin to cut a hole in 10 gauge steel with a holesaw powered by a cordless drill, so we called in the heavy artillery aka Ol' Milwaukee
yes I know WD-40 aint cutting oil but that's how they do it on TV
Old 04-05-2021, 10:53 PM   #1509
Gregski
Gregski's Avatar
not my design, something I stoled off the InterWebs
Old 04-05-2021, 10:55 PM   #1510
Gregski
Gregski's Avatar
then it was off to our brake (break?) machine to put a bend in it
Old 04-05-2021, 10:56 PM   #1511
Gregski
Gregski's Avatar
the SEMA judges love rounded corners on their brackets, so here we go
Old 04-05-2021, 10:58 PM   #1512
Gregski
Gregski's Avatar
you find out right quick who yer friends is, when you try and get some help scratching up the newly painted steering column moching it up 17 times all by yourself, using every trick you go
Old 04-05-2021, 11:01 PM   #1513
Gregski
Gregski's Avatar
and here she is before I splashed her with sum primer
Old 04-06-2021, 09:12 AM   #1514
8man
Turned out good, and it's quite substantial!
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 04-06-2021, 09:22 AM   #1515
54GMC150
Nice job on the column mount. Looks great
54GMC150 is offline   Reply With Quote
Old 04-06-2021, 09:46 AM   #1516
edgeleycanuck
Red face Re: A '54 named Busty
That bracket is going to do the job for sure! Compare that to the aftermarket peice....no comparison, you will feel good using it. I don't know if it's necessary but I welded a small stopper/tab on the column , on the bottom next to the half sleeve you have and again at the column top against whatever bracket you use. Kinda locks the column between upper and lower mounts.
edgeleycanuck is offline   Reply With Quote
Old 04-07-2021, 11:19 PM   #1517
Gregski
Gregski's Avatar
thank you, had it perfect till the very end when lacking a third arm it slid a bit on the firewall when I drilled the four holes through it 1/8th of an inch maybe
Old 04-07-2021, 11:21 PM   #1518
Gregski
Gregski's Avatar
and here she is all bolted up, exhaust clamps aint just for exhaust you know
had Ray Charles weld it up for me... with his feet!
Old 04-07-2021, 11:24 PM   #1519
Gregski
Gregski's Avatar
so Good News... Bad News
Good News: she runs and drives
Bad News: the front tires rub on the outer fender bracket bolts, you know there are two per side on the inside front of each fender, so I am thinking of switching to the smooth button head Allen bolts and considering 1/4" spacers between the radiator core support and them brackets
but this is all part of the shake out, the engine sounds soooo smooth like a Buick
Old 04-08-2021, 07:30 AM   #1520
6DoF
6DoF's Avatar
well hell, congrats!! if that's your number 1 issue after the first drive, you are doing REALLY good.
6DoF is offline   Reply With Quote
Old 04-08-2021, 08:52 AM   #1521
daddyjeep
daddyjeep's Avatar
Good deal. Glad it is driving.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-08-2021, 08:54 AM   #1522
8man
"It's alive!"
That is a big step, congratulations.
8man-aka Robert
Old 04-08-2021, 10:45 AM   #1523
Gregski
Gregski's Avatar
I know right? Thanks, she's just stretching a little bit that's all and telling me what she needs adjusted.
Old 04-08-2021, 10:46 AM   #1524
Gregski
Gregski's Avatar
Yeah brother I could not wipe the silly grin off my face while trying to look all cool driving her around the neighborhood with no hood on.
Old 04-08-2021, 11:13 AM   #1525
Tempest67
Tempest67's Avatar
Congrats, that is great news.
please post some pics (with, or without the hood)
Tempest67 is offline   Reply With Quote
