![]() Join Date: Oct 2014
LS Swap: Dimensions
Hello all. Does anyone know if you have to move the transmission forward or backward when doing an LS swap in a truck that previously had an SBC in it? I know there are mounts that allow you to slide the LS basically wherever it fits best, but I want to know if this puts the back of the block (where the bellhousing mounts) in the same location as the SBC.
I have a 73 C10 that currently has a Vortec 350 in it, and a TH350. I've decided to swap the TH350 for the new TKX transmission. I'm ready to do the TKX swap now because I really want a manual transmission and overdrive since this truck will be driven daily. To do the swap, I have to move the crossmember back, shorten the driveshaft, and cut a hole in the floor for the shifter, but I've also been toying with the idea of doing an LS swap. I can wait a while to do the LS swap since my engine currently is running really well, but I know I'll eventually want an LS. What I'm trying to avoid is having to move the the manual transmission and thus have to patch the floor and recut a new hole, get a new driveshaft made, etc. |
![]() ![]() Join Date: May 2015
Re: LS Swap: Dimensions
the ebay plates is used on my c30 swap locates the rear of the LS in the same spot as a sbc...
the
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 04-07-2021 at 07:24 PM. |
not sure exact, but i can squeeze my hand in there..and ive got big hands..
i can look tomorrow and see how much.
of the clearance ?
Either the SBC or the LS can move forward if you convert to electric fans, but the LS is a little shorter, so it can move forward further. Three inches forward and one inch upward is very common, using Tejas LS-swap mounts.
The LS can also sit in the stock SBC location. There will be no more than a finger width of room in some places between the heads, block, and the firewall. You also won't be able to run the stock LS AC compressor. You can fit that compressor in place if you use the Tejas mounts, though.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
All depends on the mounts. I also used Tejas, and used a 4L60E as well. Just moved the trans crossmember a little. Tons of room between the motor and firewall.
Gmcguy,
without pulling the covers off the engine, I couldnt get a clear pic of the clearance .. But it's a little over 2 fingers width between the pass head and the firewall..so I'm gonna say a little over 2in..theres a little more on the drivers side..I think the bellhousing would hit before the engine would if I went back..it could go further forward with no issues
#11 | |
The only place mine had fit issues was the 2" headers on the passanger side.
85 Silverado LWB Fleetside 383 Stroker 86 Custom Deluxe SWB, Pro Street LSX |
Tags |
ls swap, manual, tko swap |
