Adhesive for Window Felts
Getting my 1950 Chevy truck doors put together. Looking for a recommendation for the best adhesive to use on window felts.
Thanks. Wade
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
#2 | |
![]() Join Date: Mar 2007
Re: Adhesive for Window Felts
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
It is the channel that the glass window runs in (felts might not be the right word). Looks like it is called "upper run channel" https://www.classicindustries.com/pr...eyword&search=
It is the part that is about 8' long
#4 | |
Thank you Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 Last edited by youngrodder; 04-09-2021 at 03:02 PM. |
Thanks. I may try using a couple of small screws in the corners.
On my pickup I used Permatex Ultra Black silicone, and on my panel truck I used screws; both methods worked perfectly fine. Silicone had the advantage of holding the entire length of the channel, but the disadvantage of being messy. Some ADs I have disassembled had tiny screws in the upper corners of the window channels, but I don't know if those were factory original or not. If you do use screws, be sure to use flat heads and sink them in fully or they may damage the upper part of your glass.
This was my pickup with Ultra Black:
1951 Chevy Panel Truck |
Thanks MiraclePie.
#8 | |
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
